Injector issues....snow balled into.....something else
Postby ellis93 » Wed Nov 13, 2013 6:11 pm
Looks like I'll be pimping my 7x10s again,thinking I've a seeping weeping frankin-injector. Truck has been working a little hard here lately and this morning was no exception. I had to go get some cows loaded and at the sell barn by 7:30.....and woke up late :( . This meant hooking to the trailer and hauling as much a$$ as possible to load 5cows and cover 50miles in less than 1 1/2hrs. Everything went smoothly hooking and loading,and even the ride wasn't bad. Problem came when I fired it back off after unloading and doing paper work. It fired up with no unusual hiccup,just a blue cloud and take off found it puffing,belching blue clouds. No felt miss,no unusual vibs......just a puffing blue cloud that tends to clear after it runs for a few minutes.
Do y'all have any other suggestions? Reckon I'm on the right path :) ?
Re: Injector issues
Postby RCCUMMINS89 » Wed Nov 13, 2013 6:27 pm
Usually.......and I do mean usually (not always). An injector issue is consistent. It usually doesn't come and go.
That's common for us up here in Idaho, as it is cold.
So possible issues (in my mind). Injector, low compression, cold fuel, cold engine, or any other issue that can cause a poor burn.
Re: Injector issues
Postby ellis93 » Wed Nov 13, 2013 6:45 pm
This only happened with the engine off Eric,seemed like one bleeding off.
Re: Injector issues
Postby PToombs » Wed Nov 13, 2013 7:00 pm
Bad valve seals. It would explain where your oil is going too.
Re: Injector issues
Postby RCCUMMINS89 » Wed Nov 13, 2013 7:10 pm
So when you fire it back up it is smoking and then goes away?
Our injectors can't really bleed off. Our lines don't remain pressurized.
Re: Injector issues
Postby ellis93 » Wed Nov 13, 2013 7:19 pm
PToombs wrote:Bad valve seals. It would explain where your oil is going too.
All of a sudden tho? :scratch: I'd figure that would be a progressive thing.
Re: Injector issues
Postby ellis93 » Wed Nov 13, 2013 7:26 pm
RCCUMMINS89 wrote:So when you fire it back up it is smoking and then goes away?
Yeah gigantic blue plumes of smoke. Ridiculous amounts of smoke.
I would figure some would stay in the lines Eric,otherwise these trucks wouldn't start as fast. The pump would have to prime the lines every time you went to start it. I'm not thinking of erroneous amounts of residual pressure.
Re: Injector issues
Postby RCCUMMINS89 » Wed Nov 13, 2013 7:31 pm
Which is true... fuel stays in the lines. What I'm saying though is, if that is happening one injector would have to be stuck open or partially stuck open.... which should present with the blue/hazy/smoke at all times of driving a long with a little bit of a miss at least.
However........when the 7x10s go back in, it should change if it is injectors.
When was the last time you checked your turbo/downpipe?
Re: Injector issues
Postby ellis93 » Wed Nov 13, 2013 7:37 pm
I haven't checked it,tho I may. The oil thing has be eating at me since I lost all that last oil change. I can say I'll be checking it and my intake tube while I'm swapping those injectors. :?
Re: Injector issues
Postby ellis93 » Thu Nov 14, 2013 5:48 am
It's fuel
I freakin stink now too,just standing around it will have you smelling of raw fuel.
It's not made it tothe oil yet,its still full,not over where it was when I checked it yesterday morning.
Re: Injector issues
Postby RCCUMMINS89 » Thu Nov 14, 2013 8:20 am
Holy balls..........ya something is wrong for sure.
If it smells like fuel, I'd get those terds out asap and we'll figure out what happened.
Re: Injector issues
Postby skilletky » Thu Nov 14, 2013 8:44 am
pull the turbo and see if there is oil in the exhaust manifold. id even start it without a turbo on it and see what happens. could be the seals in the turbo.
skilletky
Re: Injector issues
Postby ellis93 » Thu Nov 14, 2013 8:52 am
Eric they're coming out. Sunday.....my ox is in the ditch. I have to much to do the next few days to fool with it and my boys bday is Saturday so....... :?
Re: Injector issues
Postby RCCUMMINS89 » Thu Nov 14, 2013 11:27 am
If it is an injector issue.........send them back to me and I'll have them gone through.
Re: Injector issues
Postby PToombs » Thu Nov 14, 2013 4:08 pm
If it's fuel it sounds like an injector stuck open, looks like it too from the smoke. I think you need some bigger injectors! ;)
