Cummins/82 C10
Re: Cummins/82 C10
Postby DodgeFreak » Mon Jan 06, 2014 5:13 pm
:D ....my brother took his 73 Charger to a friend of ours to get redone and that was 4 years ago....my brother was hoping it would be done in a year......lol....only good thing about it is it's getting done right, and he's not in a hurry for it.
Re: Cummins/82 C10
Postby dazedandconfused » Mon Jan 06, 2014 5:28 pm
Their are a few companies making kits now with paint supplies. I've heard good things about Summits paint.
Re: Cummins/82 C10
Postby RumbleFish » Mon Jan 06, 2014 5:55 pm
^this. My goober came close to getting a driveway paintjob with summit paint. Then i sold it and bought a ramcharger.
Re: Cummins/82 C10
Postby ellis93 » Mon Jan 06, 2014 6:40 pm
I'll check on it guys,thanks for the suggestion. I had no idea they sold prepackaged paint kits.
Re: Cummins/82 C10
Postby PToombs » Tue Jan 07, 2014 6:58 pm
Eastwoods stuff is expensive, period! You can get a decent name brand paint and the proper supplies from a good autoparts store usually. The name brand paint is the important thing, it's better quality and if it screws up the seller can tell you what you did wrong or how to correct it.
If you are using a regular old paint gun, keep the pressure up around 70psi for the silver, it makes the metallics stand up on edge and shows better. And like was said, silver will show if it isn't applied even. A friend of mine said silvers are the hardest to match when painting because it's so easy to get a slight shade difference, even air pressure will change it.
Maybe do the body work, then find someone to shoot it for you. There has to be somebody around who can do it, painting is the easy part, it just needs some practice though. ;)
Re: Cummins/82 C10
Postby ellis93 » Tue Jan 07, 2014 7:23 pm
Yeah Pete,I'm figuring that out :? . I was mostly interested in their kits,that included paint,sprayer,mix cups,ect ect. Now they don't have it :roll: .
Re: Cummins/82 C10
Postby 1STGENFARMBOY » Mon Jan 13, 2014 8:13 pm
I just bought the "hot rod" black kit from eastwoods at Christmas for the boys 67 GMC and it was
cheaper than federated auto and a good discount. haven't sprayed it yet though.
Re: Cummins/82 C10
Postby ellis93 » Mon Jan 13, 2014 8:26 pm
Dar,how long till you spray it? I'd like to know how it does.
I'm leaning towards their black epoxy primer and satin black hot rod stuff......for kind of a starter/practice paint job.
Re: Cummins/82 C10
Postby 1STGENFARMBOY » Mon Jan 13, 2014 9:13 pm
I wish I could tell ya, my boy seems to be more interested in playing x-box war games than getting the truck
done, I'm just about to loose it with this situation.
don't wait on me man, you can do it...just try to have a pretty clean spot to spray.
to look and act just like me, we sure don't share the same interests.
Re: Cummins/82 C10
Postby DodgeFreak » Wed Jan 22, 2014 10:59 am
My younger brother is the same way....he would sit in the house and watch tv or play video games while dad and would work on cars together, go hunting together ect. and I'm adopted...I like playing video games and watching tv but only when I have nothing better to do..
Re: Cummins/82 C10
Postby dazedandconfused » Wed Jan 22, 2014 11:02 am
So have you done anything to it?
Re: Cummins/82 C10
Postby ellis93 » Wed Jan 22, 2014 12:01 pm
A little..... Mostly just trying to get rid of the "new" rust formations that ol'cod sack made for me and covering it up with some rattle can etching primer.
I have some pics I need to post up..... :)
Re: Cummins/82 C10
Postby ellis93 » Thu Jan 23, 2014 1:13 pm
Now that I've figured the photobucket app out.....freakin updates :?
Here's what I'm left with after ol cod sack screwed me
Image~original
and last but not least....
Notice all the rust bubbling up around the edges of that bondo :puker:
Re: Cummins/82 C10
Postby dazedandconfused » Thu Jan 23, 2014 1:43 pm
That sucks. What about using something like this to get rid of the rust?
http://www.theruststore.com/Rust-Releas ... 224C1.aspx
Re: Cummins/82 C10
Postby PToombs » Thu Jan 23, 2014 5:44 pm
That bondo will all have to come off. It's porous and sucks up water like a sponge. If you sand off the rust spot and paint over the bondo you'll have rust coming thru in a few months.
Nice of him to grind it with a 40 grit wheel on the grinder and then leave it. :roll: Most of that surface rust will sand right off and be good to go. I use a Metalprep to kill the rust before I paint it, seems to work ok. A body guy I know told me to prime the bare metal with epoxy primer to seal it, then bondo and body work after that. The epoxy seals it under the bondo so it won't rust like yours did, even if it gets a scratch thru the paint, the metal is protected.
