Injection pump woes
Injection pump woes
Postby tim curran » Mon Jan 27, 2014 10:03 pm
Any body know we're to get a kit to rebuild my injection pump on my 93? I have a industrial injection stage two pump that is only two years old and it is leaking fuel every where. It leaks fuel out the drain on the back of the diaphragm housing. I checked my oil and I appear to have gained a gallon of oil this week. My shaft seal is gone to. This pump was 1100 bucks I am sick of buying junk. Does any one no where to get good parts for these ve pumps? No eBay junk I want to take my pump apart and rebuild it and replace my leaky seals. Any help would be nice. :bom:
1993 w250, 3200 RPM springs, maxed fuel screw, industrial inj. Fuel pin, Dynamite diesel 75 horse inj., ind inj stage 2 pump, 60 lbs valve springs, ARP head studs, Banks ram air intake. 4 inch diamond eye exhaust,16cm turbo housing, 60 mm comp. Housing, BD tourqe converter, billet flex plate, Banks gauges, 212hp 608 tourque, old smokey and worn out.
tim curran
Re: Injection pump woes
Postby RCCUMMINS89 » Mon Jan 27, 2014 10:46 pm
Currently all of the bosch re seal kits are on a national back order.
Have you talked to Ind. Injection?
Postby tim curran » Tue Jan 28, 2014 7:15 am
I have they said send it back and they will go through it for parts and labor. It's just the shipping. Cost from Maine too Utah plus the down time. This truck is my service truck so she works all the time.
tim curran
Postby tim curran » Tue Jan 28, 2014 7:31 am
Just got a complete seal kit from diesel fuel system's in Bangor Maine, 2079418595. They charged $20.00 we'll see how it goes
tim curran
Postby stoneagemaxx » Tue Jan 28, 2014 7:49 pm
ive also got a kit from DFS in maine I used a bosch front seal and ksb seal because I had them but everything else is from the kit been together since early November driven daily no problems yet knock on wood
91 d250. 2wd std cab i/c convert 3.07 rears autometer guages htt stage 3 turbo 47rh convert 2 manualy controled od an lockup turns on fuel screw .5 on smoke screw and fuel pin rotated 3800gsk timing jumped 1 tooth retarded on pump settings for now resealed ip to come in spring he351ve and full 4 in ex hopefully injectors coolertubz for the other rig thanks Tim
stoneagemaxx
Postby RCCUMMINS89 » Tue Jan 28, 2014 8:01 pm
Do DFS have the dgk121 kit? Or is it an ebay (aftermarket) kit?
Postby tim curran » Sat Feb 01, 2014 6:14 pm
So I fixed my leaky seals and ditched my worn out Denny t fuel pin, put my pump back on the truck. It starts and idles nice but when u give it throttle it starts to die off like the fuel is being shut off. All the work I did to the pump was in the diaphragm area on the cover of the pump, what did I do wrong. :(
tim curran
Postby tim curran » Sat Feb 01, 2014 6:16 pm
The kit from dfs was good had a ton of parts to go through the whole pump. I was told it was the kit they have been using a while.
tim curran
Postby tim curran » Mon Feb 03, 2014 1:46 pm
I had fuel lever tweaked just had to take uf top bolt of the lever and push down on the fuel rod then tweak it back a little. Took a couple of times to get it right. :bom:
tim curran
