Engine knock ??
Re: Engine knock ??
Postby tim curran » Thu Feb 13, 2014 7:42 am
Free is always great, but the stock ones don't hold up to modified power levels. I did four converters before I put my bd one in. Then my flex plate broke. For some reason it is always easy to find the weakest link. :bom:
1993 w250, 3200 RPM springs, maxed fuel screw, industrial inj. Fuel pin, Dynamite diesel 75 horse inj., ind inj stage 2 pump, 60 lbs valve springs, ARP head studs, Banks ram air intake. 4 inch diamond eye exhaust,16cm turbo housing, 60 mm comp. Housing, BD tourqe converter, billet flex plate, Banks gauges, 212hp 608 tourque, old smokey and worn out.
tim curran
Re: Engine knock ??
Postby cummins32 » Thu Feb 13, 2014 10:00 pm
When I let off the throttle going down the road I don't hear the noise, still think it's the flex plate ? I just wanna be sure before I tear it apart, I still gotta find a flexplate patc said that one wouldn't work.
Diamond eye 4 inch turbo back, Glowshift boost, egt, oil pressure,hx35 , 3200 rpm spring, full power screw 2 turns, denny T II fuel pin, Home made Cold air intake, Alto reds and tci TC in a 518, 5x12's from diesel auto power.
cummins32
Re: Engine knock ??
Postby cummins32 » Fri Feb 21, 2014 9:48 pm
Changed it today and the old plate looks fine, I still hear the knock but its not as loud now. Could it be the converter ??
cummins32
Re: Engine knock ??
Postby cummins32 » Sat Feb 22, 2014 1:45 pm
Also, when I first start it, it hazes blue lightly, could this be an injector issue causing the knock ? The engine runs great, has good power, doesn't miss, except for today after I got off work, I started it and it was missing on one cylinder for about 5-10 seconds, its about 35 degrees out also. I'm leaning towards an injector.
cummins32
Re: Engine knock ??
Postby cummins32 » Sat Feb 22, 2014 1:47 pm
What about the vacuum pump ? It just started leaking the other day also. But I've heard the noise before it started to leak..
cummins32
Re: Engine knock ??
Postby cmann250 » Sat Feb 22, 2014 1:59 pm
cummins32 wrote:Also, when I first start it, it hazes blue lightly, could this be an injector issue causing the knock ? The engine runs great, has good power, doesn't miss, except for today after I got off work, I started it and it was missing on one cylinder for about 5-10 seconds, its about 35 degrees out also. I'm leaning towards an injector.
Crack each injector and the knock will stop when you hit the right one. That'll work as long as you can distinguish a knock from a miss.
If you think the original flex plate has life left, I'll buy it. My local connection didn't follow through.
Re: Engine knock ??
Postby cummins32 » Sat Feb 22, 2014 2:30 pm
Ok, I'll do that, and if you cover shipping, It's yours, I have no use for it, I didn't see anything wrong with it.
cummins32
Re: Engine knock ??
Postby cmann250 » Sat Feb 22, 2014 2:52 pm
What's your location? I'm in Lafayette. It may be cheaper for me to just drive.
If not, do you have paypal?
Re: Engine knock ??
Postby cummins32 » Sat Feb 22, 2014 3:08 pm
I'm in knox, about an hour and a half I believe, but I do have paypal.
cummins32
Re: Engine knock ??
Postby cmann250 » Sat Feb 22, 2014 3:16 pm
You have a PM
