Wastegate actuator ?
Re: Wastegate actuator ?
Postby DodgeFreak » Fri Feb 28, 2014 6:44 pm
That housing is the same as the hx35 I have with a different actuator. Now I can't seem to get the back off lol so I'm not sure if you can reclock the gate because instead of being straight down its sideways.
Postby Black93 » Fri Feb 28, 2014 8:18 pm
This is a 60mm hx35. I just swapped the exh housing from my old wh1c, they were both 12cm.
Black93
