Help Hx35 on non intercooled
Postby Firstgen11 » Sun Apr 20, 2014 5:56 am
I currently run a h1c but have a hx35 turbo ready to go on my truck I had it on before but I didn't like the air horn match up I had to use a reducer is there anybody that can please give me a link to where I can buy a air horn for my non intercooled engine that will bolt right up and match up with my hx35 turbo this turbo came off a 04 cummins if this helps and I can rotate the compressor wheel around just please help
Firstgen11
Re: Help Hx35 on non intercooled
Postby RCCUMMINS89 » Sun Apr 20, 2014 7:50 am
If the turbo came off an 04.. it'll either be an he341 or he351. What style of compressor outlet does it have? Forward facing or v-band style?
Postby Firstgen11 » Sun Apr 20, 2014 11:04 am
ThAts just what I was told and I thought something was up but I'm pretty sure it's a v style band I'm new at this so I'm not sure how to post a picture of it
Firstgen11
Postby RCCUMMINS89 » Sun Apr 20, 2014 11:15 am
If it has a v-band style outlet, then it is more than likely an hx35. Curious to know, because that would determine what cross over you need.
The only "off the shelf" cross over that I'm aware of was from cooler tubz.... though he has retired. Hopefully another forumer who knows him better than I can let us know if he has sold the company, or? I've heard rumors of it....
Postby CumminsPower59 » Wed May 07, 2014 8:15 pm
Last I heard he sold all the jigs. I asked him this last SOP if he was done and he said yes. Rumor mill has it that ASA Modifides will be making them. There is another company making a NON-IC crossover...just can't remember where....gonna have to Google it.
Postby Kasper Cummins » Sat May 10, 2014 10:23 am
I have been looking in to make cool tubz, but mine would be out of aluminum. Im just not sure if there will be much interest.
92 W250 club cab
Kasper Cummins
Postby CumminsPower59 » Sat May 10, 2014 10:38 am
Do it! At least a few sets. I waited too long and now I wait for a used set to pop up.I'm sure other members and folks would be interested in them, especially if you can crank them out fast and sell them on a certain website ;)
Postby Kasper Cummins » Sun May 11, 2014 6:06 pm
Well I'll build a set for myself then I'll get a hold of you.
92 W250 club cab
Kasper Cummins
Postby Firstgen11 » Sun May 11, 2014 8:54 pm
Found a website that makes these they are 3in tubes from shs diesel I'm gonna buy one for my hx35 swap then it will mount up perfect
Firstgen11
Postby Douglas » Thu May 15, 2014 8:43 am
There is a 3" nipple for the HX35 that you will find useful. Columbus Diesel sells it, and I used one on my Non-IC'd 1990 HX35 swap. I did make a custom cross over tube, but with a supplier of mandrel bent tubing and TIG welder in hand it was not so difficult...:)
cheers,
Douglas
1991 D250, 727 and 16cm H1C.
Douglas
Postby JeffTheMarine » Mon May 26, 2014 9:05 pm
Second Hand Smoke Diesel sells a 3inch cross over tube on their site. I bought my 23 to 29 spline transfer case coupler and he was a great guy to deal with.
Jeff
Here is the link to the crossover.
http://shop.shsdiesel.com/3-Non-Interco ... 8991CO.htm
1981 Dodge W250 Crew W/94 12V&NV4500+NP205
Mods: Ground #100Plate,AFC Foot ground,BHAF
1990 Dodge D250 NonIC 12V Smoke screw flush,Fuel pin turned, Star wheel bottomed -5 clicks, fuel screw in 1 extra turn
JeffTheMarine
