Fuel Pin, 3200 spring = no difference?
Postby JQmile » Wed Feb 13, 2008 8:30 pm
OK so I put in a 3200 spring, and I'm not seeing much of a difference. With the stock spring I could turn it up about 4 1/2 turns (fuel screw) and still not see a runaway, but it would fuel pretty much up to 2700rpm. With the new spring it goes up to the governor if I rev it up in neutral at 4 turns, and at 3 1/2 turns it fuels up to 2700, then drops off at about the same rate. Ideas?
Also, I put in an aftermarket fuel pin, and I'm not noticing much of a difference by the butt-o-meter. It seems like I should notice 20 or 30 more hp. Could I be running out of fuel pressure? Lift pump is still stock. Again, ideas? Pin is set at the deepest position.
Thanks guys.
JQmile
Postby CumminsPride » Wed Feb 13, 2008 9:22 pm
After market fuel pin only has one setting doesn't it? Fuel pressure guage would be a good idea. Wait, DDP 4's and a molested pump and your still depending on a stock LP. Wow do you read your magazines?
06 3500 AT Mega Cab SRW 4X4
CumminsPride
Postby JQmile » Wed Feb 13, 2008 9:47 pm
Shadup :D I'm eventually going to a 14mm head so I am trying to stay away from a $500 fuel system right now. Might try a holley blue pump I have laying around.....
JQmile
Postby burnt_servo » Wed Feb 13, 2008 11:26 pm
have you changed your fuel filter recently ?
a fresh one might help right now until you get a higher flowing lift pump installed .
'93 w250 .... stock ...
burnt_servo
Postby 90cummins » Thu Feb 14, 2008 12:12 am
JQ,
There is a pin that goes in and out on the inside of the pump where you insert the fuel pin and that pin can jam, a little WD40 and moving the pin back and forth can release the pin and you will begin to see the effects of the new fuel pin, after installing the spring and grinding my pin i saw a 30hp increase on the dyno.
90 Dodge W250, non-IC -- Dual 3" Exhaust, 4" Cold Air Intake, 3200 Spring, Bully Dog injectors, Gauges, Deep Trans pan
90cummins
Postby ford69557ci » Thu Feb 14, 2008 9:10 am
with those sticks and a tweeked pump there is no way the stock fuel system will keep up. i had a holley blue and all of my banjo bolts drilled and it was still not keepin up on the top end with just 435's.
ford69557ci
Postby burnt_servo » Thu Feb 14, 2008 9:23 am
ford69557ci wrote:with those sticks and a tweeked pump there is no way the stock fuel system will keep up. i had a holley blue and all of my banjo bolts drilled and it was still not keepin up on the top end with just 435's.
i thought ddp4's and 435's where fairly similar ?
burnt_servo
Postby DTanklage » Thu Feb 14, 2008 6:57 pm
435's are way larger than stock ddp 3's
but his 3's arent stock
aaron is right, no way is the stock lift pump keeping up
piston pump it
i got one here if you need it
DTanklage
Postby CumminsPride » Fri Feb 15, 2008 5:05 am
DTanklage wrote:435's are way larger than stock ddp 3's
piston pump it
JQ is runnin 4's not 3's.
CumminsPride
Fuel!
Postby Ace » Fri Feb 15, 2008 8:34 am
Stock LP won't keep with stock I/C injectors and a good, tweaked VE. At least mine didn't. Pulled down to 2-3 psi under WOT load. You're starving that VE.
Postby DTanklage » Fri Feb 15, 2008 12:28 pm
opps, meant 4's
but he really isnt running those either
ddp opened em up another 25% over a stock 4 for him
so...they are prolly about the same as a 435 or 5x14
DTanklage
Postby JQmile » Thu Mar 13, 2008 6:28 pm
Hey guys, found out what it was, stock intake and exhaust were holding me back big time on the top end, 3200 spring worked fine.
JQmile
Postby PToombs » Fri Mar 14, 2008 5:12 pm
What'd ya do? Unhook them and run around with an open turbo to test it? :thumleft:
Postby dpuckett » Sun Mar 16, 2008 11:38 am
Ace, my Airtex junk LP wont keep up with my stock injectors and VE either, though if I only dropped to 2-3psi, it wouldnt be so bad. Mine goes to 0 with 20+ boost or 3k+ rpm.
Anyone know where to find a Carter pump?
DP
Postby PToombs » Sun Mar 16, 2008 1:19 pm
I have one sitting on my bench, but it's kinda like yours. You could double them up? :D
