Master cylinder
Master cylinder
Postby 92cummins89 » Mon Jun 30, 2014 4:19 pm
Got all my pieces made for my clutch push rod
Now I'm tryin to get the master cylinder back on the truck
Do u just put it on an twist and it locks or was there something onthe inside tht prevents it from being pushed out when u engage the clutch
1992 4x4, 4” diamond eye exhaust, nv4500, he351cw
92cummins89
Re: Master cylinder
Postby PToombs » Mon Jun 30, 2014 6:17 pm
Put it in, twist to lock, and there should be a locking screw so it doesn't untwist back out
Re: Master cylinder
Postby 92cummins89 » Mon Jun 30, 2014 6:31 pm
Where on the inside of the cab ?
U get me a pic if u don't mind
92cummins89
Re: Master cylinder
Postby PToombs » Tue Jul 01, 2014 4:50 pm
Yes, inside. IIRC it screws into the master cylinder plastic. There should be an existing hole in the master if it's a used one.
Sorry, no way to get a pic at this time. Wife dropped the camera again. :roll:
Re: Master cylinder
Postby 92cummins89 » Tue Jul 01, 2014 6:51 pm
From the looks of my old master I can't find a hole anywhere
And when I put it in an turn it with little to no pressure it pops back out looks like part the hangs on the cab tht locks it is all broken and chipped
Think I just might order a whole new master an slave
92cummins89
Re: Master cylinder
Postby PToombs » Wed Jul 02, 2014 5:52 pm
Mine stayed in, but I put the screw in it right away. Maybe the line is holding pressure on it to unscrew out. If you do get one bleed it before you put it in. I've read on here that is the best way.
