435's with a stock turbo?
Postby jimmyt83 » Thu Feb 21, 2008 10:45 am
I'm in the middle of a cummins conversion in my '94 Chevy using a 5.9 IC out of a '93 D250. Once I get her runnin, I am planning on starting the upgrades, and want to start with the fuel screw, a custom cut fuel pin, and injectors. My biggest question at this point is whether or not I can run 435's (or bigger??) with the stock turbo without running into dangerous territory. I don't mind a little smoke...just concerned with EGT's...I plan on upgrading to twins as soon as I can afford to...just not right away.
I will have a boost gauge and pyro (pre-turbo).
Thanks,
Jimmy
jimmyt83
Postby KTA » Thu Feb 21, 2008 11:20 am
You probably can't tow without egt problems on that setup, but you could drive it fine if you can control your right foot. 8)
Postby cummins king » Thu Feb 21, 2008 11:27 am
since your doing a convertion why dont you put on a hx40 or s300 and a four inch exhaust then you have the top turbo and the exhauset done for the twins
then you wont have problems with your etgs and it cheap
93 4X4 auto
cummins king
Postby ford69557ci » Thu Feb 21, 2008 5:03 pm
you could run 435's but you will need water to keep it cool and nirous to clear up all of the smoke.
ford69557ci
Postby jimmyt83 » Thu Feb 21, 2008 9:27 pm
Ok, so what sized HX-40 or S300 would be good matches for these injectors, as well as be feasable once I upgrade to twins? I don't want to run water or nitrous right away unless someone could point me in the right direction to building my own water/meth system. I've got a couple of months before this will all end up being a reality...I'm just now getting all the pieces together for the conversion, and will start it in about 3 or 4 weeks or so. Don't worry guys...I'm planning on finishing the conversion before throwing money at the expense of bigger injectors and turbo...just want to start my research now.
Sorry for the Newbieness...I've been driving the underpowered 6.5 for the last 5 years, and am just getting into the whole Cummins scene.
jimmyt83
Postby nooblet » Thu Feb 21, 2008 9:43 pm
ford69557ci wrote:you could run 435's but you will need water to keep it cool and nirous to clear up all of the smoke.
:jumpsmile:
nooblet
Postby cummins king » Fri Feb 22, 2008 6:29 am
either an s300 or hx40 with a 16cm exhaust housing, i have a hx40 and its great, but some guys like the s300 better but there hard to get
93 4X4 auto
cummins king
Postby SChandler » Fri Feb 22, 2008 3:26 pm
cummins king wrote:either an s300 or hx40 with a 16cm exhaust housing, i have a hx40 and its great, but some guys like the s300 better but there hard to get
Their only hard to get if your looking at salvage yards. Lots of places will sell you a new or rebuilt S300 but there about $500 more than a similar condition HX40 from what I've seen.
SChandler
Postby ford69557ci » Fri Feb 22, 2008 3:43 pm
a 64-71 s300 with a 14 or 16cm housing will work great so will a 16cm hx40. the s300 just offers alot more air flow and is more efficient at higher boost levels
ford69557ci
Postby DTanklage » Fri Feb 22, 2008 6:09 pm
before you buy any parts you need to decide what you are going to be doing with the truck
are you going to tow at all?
if so how heavy are ya talking and how much of the time will you be towing?
if not is this just a toy or a dd?
makes a difference for what parts i would suggest
that charger ford recommended for example, the 64/71-16, wont tow very good but would be great on a toy. then again, its a pretty big charger to end up in the top position for twins unless you are gonna be making some pretty big power.
with the big stuff you compromise bottom end
and i would be more worried about blowing the turbo up than the egts and motor damage they can contribute to with your questioned combo
5x14's are bigger than pods and pods were too big for my h1c
DTanklage
Postby ford69557ci » Fri Feb 22, 2008 6:31 pm
yeah for towing a 62-65 s300 is the bomb diggity
ford69557ci
Postby cummins king » Sat Feb 23, 2008 11:04 am
ohay i should of asked you that then you probaly want a hx40
93 4X4 auto
cummins king
Postby jimmyt83 » Sun Feb 24, 2008 9:00 am
I doubt I'll be doing much towing...if anything, my 16' ski boat, but it's not all that heavy. The truck is also getting about 8-10" of lift and a set of 38's under her. I'm really looking to build a toy out of the 'ol beast. She'll have the Dodge A518 tranny and I plan on either 3.73's or 3.96's in the rears. The tranny, I'll be sending off to Suncoast for their rebuild.
I'm also contemplating just going with a big single, and making up for turbo lag with a nitrous system. Any suggestions here??
Thanks,
Jimmy
jimmyt83
Postby cummins king » Sun Feb 24, 2008 10:32 am
what does suncoast want for a a518 rebiuld
joel
93 4X4 auto
cummins king
Postby DTanklage » Sun Feb 24, 2008 10:57 am
jimmyt83 wrote:
I doubt I'll be doing much towing... I'm really looking to build a toy out of the 'ol beast.
Thanks,
Jimmy
i would forget about any 62/65 or 65/71 and think BIG
pm josh your number, he has some ideas for a system just as you are describing that sounded good to me
i have no experience where you are talking about going to
good luck - it sould be crazy fun
DTanklage
Users browsing this forum: No registered users and 69 guests
