burnt_servo wrote:anyone run into cooling problems with a big intercooler and the stock rad ?
Whating for summer to find out!
anyone running a aftermarket / larger than stock rad ?
what about aluminum rads ? do they exist for our trucks ?
flashgordon wrote:burnt_servo wrote:anyone run into cooling problems with a big intercooler and the stock rad ?
I'm hoping that the intercooler will actually help on coolant temp. If the EGT's go down, there should be less heat transferring into the coolant.........Right?......................
Well I'm not convinced yet either.............But my next project might be putting a 2nt gen Radiator in (Since I allread have the 2nt gen cooler) or maybe just a intercooler radiator, housing and hoses.
burnt_servo wrote:how easily does the 2nd gen rad bolt up , and any idea how much bigger it is ? , i think i can get my hands on one out of a 1999 .flashgordon wrote:burnt_servo wrote:anyone run into cooling problems with a big intercooler and the stock rad ?
flashgordon wrote:Have you done the updated fan and clutch off of a 2nt gen???????
burnt_servo wrote:
also i don't know how this might affect things , but i would like to use a '77 powerwagon grill and hood .
DTanklage wrote:so if i sw my fans my 1st gen will cool better and my 2nd gen will put more hp to the wheels?
burnt_servo wrote:i'm kind of starting from scratch here , since the rad and rad suport is all smashed into the front of the motor , and everything between the intercooler and front of the motor needs to be replaced ( i think the ac coils might still be good ) .
moving the battery tray around isn't an issue , when i first got the truck i was seriously considering clipping the windshield posts , and across the floor just a hair in front of the rear door posts , then welding in the same section out of a club cab , then finding a short box to replace the long box .
i have to replace alot of stuff , and while i could replace it all with stock stuff , then possibly end up changing it out latter , or just maybe find what you guys have changed out , and seriously consider that from the begining .
i've been wanting to dig in and take some more pics , but it snowed another 8 inches last night and burried everything ... again !!!**&&*%^%
flashgordon wrote:[
Ya forgot about it being crashed![]()
Here is the numbers just in case you are interested!
[b]Upgraded OEM Fan and Fan Clutch
Dodge has issued an updated Fan which has more twist on the blades and is lighter. If you plan on upgrading your fan clutch, I strongly suggest you also upgrade to this new fan. Again, this is an OEM component from MOPAR.
Fan- 52028653
Clutch module- 52028760
It's lighter and stronger (the fan)
As of 3 mouth ago, when i bought mine(which i can't use)they were still available.
Flash
