Installed my gauges.
Postby nooblet » Mon Mar 03, 2008 4:25 pm
I was going to get Isspro's, but I really liked the way these look! Anyone else running Phantom II's?
Chris
nooblet
Postby GO OVRIT » Mon Mar 03, 2008 8:41 pm
I like them better than mine. :grin:
GO OVRIT
Postby PToombs » Tue Mar 04, 2008 5:11 pm
They look a lot better than in the catalog. Nice! :thumleft: [/b]
Postby greasemonkey » Wed Mar 05, 2008 9:00 am
who makes that guage pod? apparently I've been out of the loop, that's the first I've seen an A-pillar 1st gen pod...
'93 250 4x4 NV4500, flatbed, club cab, ex brake, pump tweaked, too many new ideas thanks to you guys.
dubbed the "Mexican Mtn Goat"
..if you find yourself in a fair fight you did not properly prepare..
..hot rodders are the original recyclers!..
greasemonkey
Postby cummins king » Wed Mar 05, 2008 2:34 pm
same here, i made all custom gauge set uf for mine because i couldnt find one, do they have a 3 guage one
ck
93 4X4 auto
cummins king
Postby PToombs » Wed Mar 05, 2008 2:47 pm
2 guage pods are common. I haven't seen any 3's in my travels on the web. :cry:
Postby roxxx » Wed Mar 05, 2008 3:11 pm
Auto meter part #15198 I bought mine for around 25 buck$
1992 4x4 Reg cab LE 5 speed
4 Inch lift
Bilsteins shocks 5125
VE moderately molested
Dana 80
ultra wheel rims Type 164
ASA pipe BHAF 19037
Outerwears prefilter
A A nv4500
roxxx
yo
Postby SiKK » Wed Mar 05, 2008 3:44 pm
is that glue on your pod? :?
2.4L Turbo
SiKK
smoke screw?
Postby PToombs » Thu Mar 06, 2008 3:08 pm
Oh Man! I didn't notice that! :shock: We gotta deduct 10 rwhp for unsightly use of silicone! :oops:
You shoulda left it bare, it looks better. ;)
Postby nooblet » Thu Mar 06, 2008 7:59 pm
PToombs wrote:Oh Man! I didn't notice that! :shock: We gotta deduct 10 rwhp for unsightly use of silicone! :oops:
The pod is a generic one made by Auto Meter, so it doesn't fit the contour of the A-pillar molding (doesn't fit mine atleast). So it was either have a big gap there, drill another whole and put a screw, or silicone it. If I just left it I doubt those little plastic clips would have held it for very long and I didn't really want to put a screw right in the center of the pillar, so I used clear silicone. The camera flash makes it look worse than it actually does.
On another note my Pyrometer has stopped working properly. Auto Meter told me to ship it to them so they could fix it and send it back. I was not too happy to say the least... The reason I bought an Auto Meter gauge is because they are supposed to be top of the line, not work for 1 day then crap out. I explained what it was doing to the tech on the phone and he said it was more than likely a faulty gauge, not a problem with the install or the Thermocouplar.
So $20 shipping later I have no pyro for probably 2 weeks :mad:
Chris
nooblet
Postby nooblet » Thu Mar 06, 2008 8:01 pm
ATM-15198 is the one I bought.
http://www.egauges.com/vdo_acce.asp?Sub ... _1986_1993
Chris
nooblet
Postby whereswaldo250 » Fri Mar 14, 2008 7:39 pm
where did you run your gauge wires through the fire wall?
1992 Dodge W250 standard cab STRAIGHT PIPED! black 3/4 ton Cummins Turbo Diesel Intercooled, 4x4,148000k, getrag 5 speed, np205 transfercase with PTO, D60 in the front, D70 in the rear posi (4:10 gears), Mods soon to come
whereswaldo250
Postby nooblet » Sat Mar 15, 2008 9:16 pm
whereswaldo250 wrote:where did you run your gauge wires through the fire wall?
Uh... I don't really want to answer this question :oops:
If you guys made fun of the silicone on the pod... your really gonna give me sthi about this.
Follow the hood latch release. The grommet that the cable goes through is very thin. Mine had a gash in it, so previously I had run a wire through it when I wired my A/C compressor to a relay instead of the temperature sensor on the expansion valve. I made that gash much larger and ran all my lines (including the thermocuplar) through there :evil:
I really don't recommend this, for the record. It really does look pretty awful if you look under the dash.
Before you guys tell me how ghetto I am, trust me... I know ;)
Chris
nooblet
Postby whereswaldo250 » Wed Mar 26, 2008 5:38 pm
Aww thats ok I don't judge :D I'm thinking about drilling a hole in the fire wall so I can run everything through that central hole. With the right side grommet it should look pretty factory.
BTW I tried running it through there and I did slice min and yeah not the best idea :evil:
whereswaldo250
Postby dpuckett » Wed Mar 26, 2008 7:11 pm
What's wrong with slicing a grommet opening a little bigger to push wires through? All of mine have had that done. :roll:
Anyway, Autometer may be top of the line in some fields, but diesel pyrometers have gained them a bad reputation. I wont buy any, for sure. I have had ISSPRO in about 4 trucks, and Danin (formerly DiProcol) came in my 92 W350. They dont look bad, but the white background looks out of place in a 1stGen.
Daniel
