what block is stronger?
Postby GPSMatt » Fri Mar 07, 2008 3:43 pm
picked up a 95 complete 12v motor also have a 93 motor. I have 2 4x f350s one single cab 4x and one crew cab 4x the crew cab is getting the p pump and doing everything to it the other is gunna be my daily driver/tow rig with the ve so i am not going to crazy on it but is there really a diff in the blocks i want to obviously use the stronger block for my p pump truck.
86 F350 idi
85 F350 crew cab 4x 5.9
95 Lightning
85 GT
GPSMatt
Postby Begle1 » Fri Mar 07, 2008 5:42 pm
I think that block strength has more to due with where it was cast than the year.
There are numbers on them somewhere that you can trace back. I think.
Postby greasemonkey » Fri Mar 07, 2008 11:58 pm
the later 12v's had the '53' block but they haven't been a problem, I don't believe the 12v '53' was made until late 97 or 98. the '53' block cracking is a very common issue with the 98-02 24v.
you should be fine with your '95 and '93 blocks, as far as I know the 95 is stronger than the 93, if that's what you're asking. good choice for the engines, the VE engine mildly modded will make an awesome driver and gets the best mileage in my experience; and the P-pump is just dirty easy to turn up and is super reliable at high power levels...some people say it's cheating.
'93 250 4x4 NV4500, flatbed, club cab, ex brake, pump tweaked, too many new ideas thanks to you guys.
dubbed the "Mexican Mtn Goat"
..if you find yourself in a fair fight you did not properly prepare..
..hot rodders are the original recyclers!..
greasemonkey
Postby GPSMatt » Sat Mar 08, 2008 1:28 pm
my plan was to swap all the ve sthi over to the p pump block because it was rebuilt a few years ago that way i dont have to fkcu with it the 93 engines odometer soped working at 390k and it was a ranch truck that from the looks of it towed goose neck horse trailers all its life but the engine ran better than my friends 04. what ever i end up doin for now on what ever motor goes in my dd i anm gunna do some mild head porting oring the head 12m studs 60 lb springs and the hx35 turn up the pump and call it good for a little while oh yeah and its proly getting a 47rh.
86 F350 idi
95 Lightning
85 GT
GPSMatt
Postby dpuckett » Sat Mar 08, 2008 5:08 pm
I'd leave the 93 block alone, and keep the VE stuff with it. If it pulled all its life, it's probably in better shape than most here, and has a good 400k left in it. I had a 90 with 440K (so the P.O. said, anyway) that idled and revved as smooth as the Lexus commercials from the early 90s. Never saw the inside, but it had less blowby than my 92, and sounded better.
Put the recently rebuilt engine in your toy.
Daniel
Postby GPSMatt » Sun Mar 09, 2008 2:53 am
yeah the 93 was a bone stock truck.
86 F350 idi
95 Lightning
85 GT
GPSMatt
Postby DTanklage » Tue Mar 11, 2008 7:08 pm
Daniel
that is what i was going to suggest
my '92 had only half your miles but i am tellin ya, the bore is like new and the valve job, this is the incredible part, it had a little carbon or what ever on it but after bead blasting i could not believe my eyes - practially no wear at all. the valves were a diff story - ex were as nice as the seats but the intake valves had some wear (on the valve face)
that motor had towed all of its life too
DTanklage
Postby cummins king » Tue Mar 11, 2008 7:29 pm
what i hear, is an industral block out of a generator is the strongest block, i know hasily biult a motor for a guy and its holds 110 to 120psi
93 4X4 auto
cummins king
Postby DTanklage » Wed Mar 12, 2008 1:13 am
cummins king wrote:
110 to 120psi
childs play
if you aint pushin over 200 you dont stand a chance at beating kta's record
DTanklage
Postby cummins king » Wed Mar 12, 2008 6:35 am
200 pounds of boost, whats he running 5 turbos or somthin :lol:
93 4X4 auto
cummins king
Postby burnt_servo » Wed Mar 12, 2008 7:48 am
DTanklage wrote:
cummins king wrote:
110 to 120psi
childs play
are you serious ??? .....
what was he using to keep the head sealed ? .... wait wasn't he running 15-1 compression marine pistons ?
'93 w250 .... stock ...
burnt_servo
Postby cummins king » Wed Mar 12, 2008 8:21 am
im sure he was making a mistake, or he was joking, the top guys are only running 120 pounds
93 4X4 auto
cummins king
Postby DTanklage » Wed Mar 12, 2008 9:01 am
3 turbo's
compounded
ea puttin out over 70 psi
no joke
no ic
just a water system that will drain lake mead in a couple of minutes
DTanklage
Postby burnt_servo » Wed Mar 12, 2008 9:23 am
has he ever done a thread on this anywhere , with pics ?
or is this "top secret ?
love to see what he did , and how he went about doing it .
burnt_servo
Postby seeker1056 » Wed Mar 12, 2008 9:29 am
once upon a time in never never land ...................there were three littles turbos.....................and then along came huff n puff n ....well u know how the rest of the storey goes
;) :roll: :lol: :D
Brian readily claims 70 psi total which isnt that hard to do with a big set of twins
Sponsors of new truck
Performance Diesel Injection
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
Users browsing this forum: No registered users and 70 guests
