2016 BS and Chat Thread!
Re: 2016 BS and Chat Thread!
Postby txs » Tue Mar 15, 2016 11:00 am
Friend of mine found a first gen dodge minivan, sedan delivery style short wheelbase 2.2 5 speed. the windowless vans were very rare, I saw one at Chryslers at Carlisle a few years ago, tubbed, subframed, sporting a mid engine 440. He was wondering what it would be worth has nice body and interior, motor stuck, been sitting.
txs
Postby meby » Tue Mar 15, 2016 7:19 pm
I got the motor from the welder mostly installed into the Wheel Horse tonight. I got if far enough along to fire it up.
-1991 D-250 bone stock
-1997 Civic Hatchback
-Case 530 CK
-Speedex Walking Tractor.
-BCS Walking Tractor
www.ebyfarmsllc.com
meby
Postby DodgeFreak » Tue Mar 15, 2016 8:37 pm
txs wrote:Friend of mine found a first gen dodge minivan, sedan delivery style short wheelbase 2.2 5 speed. the windowless vans were very rare, I saw one at Chryslers at Carlisle a few years ago, tubbed, subframed, sporting a mid engine 440. He was wondering what it would be worth has nice body and interior, motor stuck, been sitting.
I don't think its worth a whole lot. You are selling to a small group of people. 2.2's are getting harder to find. Most people have scrapped them.
Postby Philip » Wed Mar 16, 2016 6:14 am
Yea for a good reason. 40k head gasket changes. If the engine was turbo'd drop that to 20K head gasket changes. Plus they were very under powered.
Put a family onboard it wasn't enough engine to hold speed on a small hill. If you hit a big hill be ready to push.
Postby spencerdiesel » Wed Mar 16, 2016 11:53 am
Rebuilt the carb on the 046. When I rebuild the HT75 ill buy online. $26 for a kit.....dat some junk
Postby DodgeFreak » Wed Mar 16, 2016 12:32 pm
I've gotten more than 40k out of head gaskets lol but once they go if they got hot at all you're looking at another head. I've ran 5 cars with 2.2 and the 2.5s and had good luck with them other than if you get them hot.
Postby DodgeFreak » Wed Mar 16, 2016 12:36 pm
I know a couple people mess with 2.0s and I'm wondering if anyone has the tool to install the crank gear and if I could borrow it.
Postby RumbleFish » Thu Mar 17, 2016 6:56 pm
Are you talking about for the timing belt DF? I used a hotplate to heat my last one (ok, the only one ive done) enough til itd slide on, then eyeballed it. Got lucky and it looked good. Other trick Ive seen is to heat the gear until it will slide on, then install the crank balancer/pulley right away before the belt drive gear is cool and it will set it to the correct depth.
Postby RumbleFish » Thu Mar 17, 2016 6:58 pm
A friend of mine had one but with an auto. It was a rot box and you could see the ground from inside the van. Theres another one running around here and its immaculate. Guy uses it to sell junk at flea markets.
Postby DodgeFreak » Thu Mar 17, 2016 7:49 pm
RumbleFish wrote:Are you talking about for the timing belt DF? I used a hotplate to heat my last one (ok, the only one ive done) enough til itd slide on, then eyeballed it. Got lucky and it looked good. Other trick Ive seen is to heat the gear until it will slide on, then install the crank balancer/pulley right away before the belt drive gear is cool and it will set it to the correct depth.
Yeah, the first one I done I must have gotten lucky because I just beat it back on and it's been good for 60k miles lol. This one I beat it on some but it's taking more force than the other one so I stopped. If the balancer sets the depth I may try to find one and cut the balancer off then turn the inside so it slides on and off and make my own.
Postby meby » Fri Mar 18, 2016 4:43 pm
Got the motor finished with all the shields in place, exhaust hooked up and wiring cleaned up. It runs great now! I can't wait to put ag lugs on it and load the tires.
-Case 530 CK
www.ebyfarmsllc.com
meby
Postby stillsmokin » Sat Mar 19, 2016 7:56 pm
I'm back, spent all of last year saving for and building a shop. The building is done, put in a 6" concrete floor. Going to try to work on the driveway tomorrow with a friends skid loader. Nice to have a shop in my backyard... in town. The shop put everything else on hold.
Might resurrect the puller again once I have the electrical buried and the wiring done inside.
92 W250LE REG CAB, SLED PULLER, S400
93 W350LE EXT CAB, dually, 5 speed
stillsmokin
Postby ellis93 » Sun Mar 20, 2016 4:00 am
Nice to see you post again^^^^
Postby meby » Sun Mar 20, 2016 6:37 am
stillsmokin wrote:I'm back, spent all of last year saving for and building a shop. The building is done, put in a 6" concrete floor. Going to try to work on the driveway tomorrow with a friends skid loader. Nice to have a shop in my backyard... in town. The shop put everything else on hold.
I built my shop last year too and its not done on the inside either, but going from shadetree status to a shop makes a huge difference! 8)
-Case 530 CK
www.ebyfarmsllc.com
meby
Postby DMan1198 » Sun Mar 20, 2016 1:20 pm
Ditto on what Ellis said. I think I got my pyro sorted on The Roo Hunter. I'm pretty sure the thermocouple pins pulled out of the connector enough to mess up the reading, so hopefully it's good now. I also got about half the mods done to my overhead pod to have that mounted how I want. Just need to get more 1/8" air line, so I can run both boost gauges up there. I also finally got the bung welded into my cold pipe, so the 2nd boost gauge has something to hook up to.
