4" + exhaust question
Postby fourwheelininajeep » Fri Mar 14, 2008 10:04 am
so a dual 3 inch would equal out to something like 14.14 inches/2 not to impressive for that same equation six inche pipe would be something like 23 inches/2 not even close, so I am better off going with some kind of 4" if its possible
1990 dodge w350 cab and chassis frame single rear wheel 99000 miles with chrome stacks between cab and bed paid 1300 for it after a years worth of work i got to drive it
fourwheelininajeep
Postby SChandler » Fri Mar 14, 2008 11:45 am
4" is possible. I have the Stan's Exhaust 4" system (4" the whole way, including downpipe) on my 92 4x4. It took a little bit of attention to get the pipe in there so it didn't make contact anywhere, but it fits. It's raining right now or I'd get pictures. I also have a 4" system on my 90 2wd but it only has a 3" downpipe. It is 4" next to the transmission and clears fine. You don't have to get really creative until you go to 5". I don't think you need (want is a different story :P ) 5" unless you're running a turbo with a 5" outlet. Just my $.02
SChandler
Postby cummins king » Fri Mar 14, 2008 2:26 pm
a 4 inch is somthing like 12.??inhces square and 2 threes is like 14.15 inhces square, two 3s is about 8% bigger then 1 4 inch, for the diffrence 1 4inch would be better
4 inch exaust is easy to do, compared to a 5inch but even a 5 inch wasnt to bad
93 4X4 auto
cummins king
Postby fourwheelininajeep » Fri Mar 14, 2008 2:34 pm
Stans exhaust? Could you get me the web site for that or where to find it
fourwheelininajeep
Postby SChandler » Fri Mar 14, 2008 3:30 pm
So, the name of the place is actually Stan's Headers. You can also try Source Automotive, they have a full 4" exhaust for our trucks (downpipe to tailpipe). Click on the names for the websites.
SChandler
Postby SNOOT » Fri Mar 14, 2008 3:38 pm
Stan is the manufacture his shop is huge. I would say that he is also one of the nicest guys around when it comes to exhaust.
I have his 4" system also.. From the muffler back I have a 5" over the rear axle tail pipe they did also.
I like the way the larger pipe sounds real low sound..
1993 W350
SNOOT
