Just a little more . . . . .
Postby RCCUMMINS89 » Thu Jul 07, 2016 10:20 pm
I am reading by the way.
Postby BC847 » Fri Jul 08, 2016 5:46 pm
fatty wrote:David, what was your mph on the recent runs compared to with the old setup? You showing any power gains there?
Found two of the three slips.
06/31/16, 7:43p
RT = .471
60' = 2.217 (All tires bouncing BIG-TIME out of the hole. Got off it a little, and on it again).
330' = 6.197
1/8 = 9.180
MPH = 83.84
06/31/16, 8:45p
R/T = .278
60' = 1.781 (Better, but still shuddered hard. Still feathered the throttle a little).
330' = 5.321
1/8 = 8.352
MPH = 80.62
In both passes above, the trans slipped going into third (NEW issue). Again, had to back-off a little and let it catch, then hit it again.
My best at this track before its rebuild was 7.97 or so. The best avg was 8.05 @ 83 ~ 84 IIRC.
Postby fatty » Fri Jul 08, 2016 9:03 pm
I wish I understood the physics behind drag racing a little better. How can you run .8 slower time but gain 3 mph?
Postby RCCUMMINS89 » Fri Jul 08, 2016 9:59 pm
Blowing off tires down low, with more power? Bogging things out down low (slow spool) and yet more power. Either way, things are slower right off the get go.
Postby BC847 » Thu Jul 28, 2016 4:51 pm
OK, let's try this again.
Metal valve-stems installed.
More to follow. ;)
Postby DodgeFreak » Thu Jul 28, 2016 7:27 pm
Lookin good!
Postby DMan1198 » Thu Jul 28, 2016 7:28 pm
fatty wrote:I wish I understood the physics behind drag racing a little better. How can you run .8 slower time but gain 3 mph?
I can't remember the exact number, but 60' time makes a huge difference at the top of the eighth/quarter. For every tenth of a second you shave off your 60' you shave a bunch more off your et.
Those wheels look pretty nice. I'm interested to see how they look on the truck.
Postby RCCUMMINS89 » Thu Jul 28, 2016 11:36 pm
It's 2:36 your time.............. why don't we have install pics yet?
p.s.......... why is the 1st gen clock an hour slow?
Postby PToombs » Fri Jul 29, 2016 5:31 pm
Those wheels are nice. I wonder how they'll look on my truck? And yeah, what Eric said! :evil:
Eric, my clock is right on, maybe in your user control panel adjust the time?
Postby RCCUMMINS89 » Fri Jul 29, 2016 8:51 pm
It shows 7:51 when I post............it's 8:51 here :?:
Postby DMan1198 » Fri Jul 29, 2016 9:55 pm
It's says you posted 8:51 on mine. Interestingly mine is doing the same thing.
Edit: I went through user cp, and it has a button for summer/dst, checked it, and all is well
Postby BC847 » Fri Jul 29, 2016 10:51 pm
The holes for the lugnuts in the new rims are too small for my current lugnuts. :roll:
I'll have a set come Monday.
Postby BC847 » Sat Jul 30, 2016 7:18 pm
This is killing me . . . .
Postby RCCUMMINS89 » Sat Jul 30, 2016 8:04 pm
Why is it killing you?
Postby BC847 » Sat Jul 30, 2016 8:47 pm
Once again delayed in getting the truck back on the road . . . . and it be safe to drive.
All along, the current tires are very well worn. The former slop in the steering combined with me aggravating the alignment with me repairing the steering system, one of the front tires had its inner section worn well into the wires. Now its one of the "MayPop" variety.
Need new tires. Can't find a set of acceptable tires (31ish in dia, acceptable street tread design, and fit a 16x10 rim). Gotta up size the rim, which leads us to now. The truck's been only good for a risky weekly trip to the landfill.
The rim order was placed in early April IIRC. It's been like pulling teeth as they say since.
