Injector questions
Injector questions
Postby oldestof11 » Tue Mar 18, 2008 4:42 pm
OK, now I am being industrious and going to build up a truck performance shop and wanting to do some things to make the VE more capable. So injectors are in the line up.
When we say 6x20 do we mean 6 holes at .20" size or 6 holes at .020" size?
Also, what is better? EDM's or something a little more precise? Laser?
Also, the injector spray angle, how do I find that out?
Thanks!
Postby PToombs » Tue Mar 18, 2008 5:03 pm
Jon, .25 is 1/4 of an inch. So 6 x 1/4 inch is a big hole! :shock: It's .020, 20 thousandths of an inch.
Philip had a pic someplace of a tip with needles stuck in it, showing the angle. I don't know how to figure it. :oops:
Postby Philip » Tue Mar 18, 2008 5:33 pm
You mean these two pic's Pete.
Postby GO OVRIT » Tue Mar 18, 2008 6:32 pm
Is that a ve tip?
GO OVRIT
Postby oldestof11 » Tue Mar 18, 2008 6:35 pm
Ya Pete, I was a little confused and that is why I thought thousandths but you never know. People have said the VE wont ever make HP but we are going to prove them wrong.
Thanks
Postby Philip » Tue Mar 18, 2008 6:43 pm
The top pic is a VE tip. The bottom is a 2nd gen tip.
Postby PToombs » Tue Mar 18, 2008 7:01 pm
Yup! Them pics! ;)
Postby ford69557ci » Tue Mar 18, 2008 8:07 pm
I could be wrong but i think the first gen tips spray angle is 145??
ford69557ci
Postby cummins king » Tue Mar 18, 2008 8:40 pm
edms are great, what are you going to sell at your shop
joel
93 4X4 auto
cummins king
Postby oldestof11 » Wed Mar 19, 2008 1:59 pm
Ok Cumminsking, that is another thread ;)
But I want to make injectors, Hot Rod Ve's and fuel line kits, head porting and polishing, transmissions, fabbing twins, lift kits and tires, gauges, etc. Also I will be dealing with the 6.9L Ford. I know, not enough power, right? Hmm....http://www.diesel-central.com/forums/de ... opicID=270
After reading that, I know the 6.9L, the 7.3L and the VE are all capable of making HP, now to market to those group of people. They are plentiful and not too many companies want to dabble with them.
Of course, the diesel repair shop would be the bread and butter part until the performance side of things pick up. Also, while the poor fool who comes to the shop and has his truck fixed, he will be hearing from me "You know, a little fuel goes a long way....""Did you know this tyoe of engine made xxx hp just a few months ago..." Nothing like a captive audience while you fix their truck :lol:
So those are the plans.
Postby cummins king » Wed Mar 19, 2008 2:25 pm
cools should be good time
93 4X4 auto
cummins king
Postby krazykarl454 » Sun Mar 30, 2008 8:18 am
dude. i don't mean to burst your bubble. but if you thought an injector tip had 1/4 inch holes in it, i would question you running a perforance shop. what kinda mechanical back round do you have? it would suck to get in over your head on something like this
86' GMC 3500 (cummins swap: hx40, POD's, I/C 5" exhaust) , custom 4-link front end, about 9-inchs of lift, dana 60 4.56s welded/ 14-bolt, 4.56s detroit. grooved 38.5 x16 TSLs, custom frt/Rr bumpers, 16.5 super sinlge welds
krazykarl454
Postby cummins king » Sun Mar 30, 2008 10:17 am
in his defence 6x20 is a wrong messurement, we use it for short instead of 6x 0.002, so i could see how sombody could get confused, we all have to learn, when i first started i couldnt tell the difrence from non ic and ic :lol:
93 4X4 auto
cummins king
Postby oldestof11 » Sun Mar 30, 2008 11:15 am
I have never physically seen a injector tip, just pics. So whenever I have seen 6x20, I think .020. But I could have been wrong. I am known to be wrong and was just clarifying.
AS for mechanical back ground, I have help rebuild quite a bit of gas engines, not diesels. Like most of us, diesels are new and takes sometime learning from them.
Up until last Febuary 07, I thought the DMax had the record for HP. Was I ever wrong...
