Engine build progress report #2
Postby seeker1056 » Sat Apr 12, 2008 5:55 am
I took it to a machine shop - we destroyed three tools before we gave up
The rockwell on this gear is horrendous, and appears to be all the way thru not just a surface treatment
We didnt even scratch it with carbides, and an experiemtn with a little brake hone didnt touch it either
its only like .0019 we need to remove
Sponsors of new truck
Performance Diesel Injection
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
Postby Fnschlaud4620 » Sat Apr 12, 2008 8:01 am
I will try to check the rockwell hardness of te gear.
Take the gear to an automotive machine shop that can resize rods. A rod hone machine dosent compare to a brake caliper hone. It will be able to remove the .0019 you need for sure.
Fnschlaud4620
Postby dazedandconfused » Sun Apr 13, 2008 3:04 pm
Looks good so far. I tried to check your pic links but it does not work.
Postby Fnschlaud4620 » Sun Apr 13, 2008 3:30 pm
Yeah, www.cummins-conversion.com site is down for a while, the owner is in IRAQ right now, I hope it get fixed soon.
Fnschlaud4620
Postby dazedandconfused » Sun Apr 13, 2008 3:40 pm
Ok I see, thanks for the help.
Postby mhuppertz » Thu Apr 17, 2008 6:41 pm
How did you determine the mass of the torque plate? Sweet tool!!!!!
So, you going to rent that baby out or what!
mhuppertz
Postby cummins king » Thu Apr 17, 2008 8:17 pm
what studs are you using ARP or haisly h11's at a price of 700+
and are you going to knife cut the crank
93 4X4 auto
cummins king
Postby Fnschlaud4620 » Thu Apr 17, 2008 8:41 pm
mhuppertz wrote:How did you determine the mass of the torque plate? Sweet tool!!!!!
I dont know yet I havent weighted it. Yes I want to rent it in the future but I have to build a protective box first. Shipping to and from New Mexico would be quite expensive.
Fnschlaud4620
Postby Fnschlaud4620 » Thu Apr 17, 2008 8:51 pm
cummins king wrote:what studs are you using ARP or haisly h11's at a price of 700+
They are A1 14mm from Jetpilot on comp D I got them new for $550.00
No, I am not going to knife the crank, but it is being balanced.
Fnschlaud4620
Postby mhuppertz » Thu Apr 17, 2008 9:12 pm
Not as expensive as me making one from scratch!
mhuppertz
Postby mhuppertz » Thu Apr 17, 2008 9:15 pm
You have to be carefull with knifing the crank using stock (heavy) pistons and rods. If you take too much off the throws you have to spend big bucks on mallory metal to get it to balance internally. It's a good idea to put an oil shedding high tech coating on the throws though... A windage tray would be good too.
mhuppertz
