I have a 91 non-ic motor I put in a 1998 ram (was a 360 blew up had the 91 motor already)
I have mated a 47rh out of a 95 with lock up and od.
I will put those on a switch so not a prob.
My questions are:
Should this motor have a tps? it does not but why would i need it.
Anyone have pics and info on the sensors on the motor ie temp,oil pressure,rpm. I would like to tie into the dash and need to know if they are sweeping type or just dummy lights.
charging system?? not sure if I am going to try to tie it in or use the existing harness and modify it to fit the older alternator?
Any help would be great.
Thanks
mike
