pyro gauge
pyro gauge
Postby grumpy » Sun Jun 01, 2008 4:07 pm
just installed it today..now I have too figure out the yellow and red wire goes.I'll check with bank's.thank's snoot again for installing it
93 dodge w350 excab daully auto 3600 gov spring 4" streight pipe,hx-35/40 turbo
91 jeep xj trail rig I-6 5spd exo cage 7inch lift
87 35ft gooseneck trailer soon to have 79camper on it.
grumpy
Postby Begle1 » Sun Jun 01, 2008 4:18 pm
Yellow is positive (+), red is negative (-).
Thermocouples use the red as a negative. Strange, but commonly wired backwards...
Postby grumpy » Sun Jun 01, 2008 4:24 pm
don't you have to run power too it some how???
grumpy
Postby Begle1 » Sun Jun 01, 2008 4:42 pm
Yes. There should be a 12 volt ignition and ground to power the gauge, the positive and negative probe leads to give the gauge the signal, and there is probably a light too.
Postby 82F100SWB » Sun Jun 01, 2008 5:33 pm
Not necessarily, the older Banks pyro I had on my 6.9 was a self powered gauge, the only other connection other than the TC wires was for the backlight.
92 W250 SLE reg cab, 5 speed, guages, screws fiddled with...
89 W250 reg cab, 5 speed, all stock but who knows... LOL
86 F250 4x4, "460"/4 speed, the toy.
82F100SWB
Postby grumpy » Sun Jun 01, 2008 6:00 pm
yeah I think that's what I have is the old pyro
grumpy
Postby Richie O » Sun Jun 01, 2008 6:08 pm
I have heard that some gauges read very slow. They take a long time to show actual temp. The temp goes up and down very quick. I have heard guys that replaced gauges and are shocked at the diffrence in gauge speed. Just something to watch.
Postby grumpy » Sun Jun 01, 2008 6:17 pm
I'm sure it has a lot too do with where you mount the probe too
grumpy
Postby SNOOT » Mon Jun 02, 2008 7:17 pm
http://www.bankspower.com/OwnersManuals/96325.pdf
No power needed except for the lights big guy!
Remove the bare shorting wire from
between the gauge terminals and
attach the spade terminals to the back
of the gauge. Connect the yellow wire
to the (+) terminal and the red wire to
the (-) terminal. If the lead wires are
accidentally reversed, the gauge will
read backwards.
1993 W350
SNOOT
Postby grumpy » Tue Jun 03, 2008 1:24 pm
you the man lance thank's again for the install and now the install site.
grumpy
Postby SNOOT » Tue Jun 03, 2008 6:24 pm
I couldn't believe it was that simple. We could have hooked it up and tested it while you were at my place.. ;-)
1993 W350
SNOOT
Postby oldestof11 » Tue Jun 03, 2008 7:30 pm
My stewart warner gauge is self powered. And it MOVES just as fast as my bro's autometer
