hx35
hx35
Postby 89silverbullet » Tue Jul 08, 2008 11:25 pm
does a hx35 bolt right up or does it need some modding? sorry moderetly new to this.
1989 d250 muffler delete diaphram turned, fuel screw turned, the lowes special intake
89silverbullet
Not on an '89
Postby Ace » Tue Jul 08, 2008 11:42 pm
It's got a 4" inlet and a wastegated turbine housing. Assuming it was one with the v-band exhaust clamp (I believe some later years came with the cast elbow?), you would need to shorthen the downpipe about an inch to accomodate the wider wastegated housing, get a 4" inlet tube from the airbox, and maybe tap in somewhere for boost pressure to operate the wastegate. Fairly trivial, but not exactly "bolt-on."
Postby 1tondodge » Wed Jul 09, 2008 7:04 am
Yep bolts right on, my intake hose went right on - no mods. I put on a 4" downpipe at the same time so I dont have any recommendations on moving the exhaust back but you will have to. Also, you might as well grab the metal gasket that goes between the manifold and the turbo while you have it apart...
92 D350 5 speed - HX35, fuel screw cranked and pump tweaked, 4" turbo back exhaust and gauges
92 Jeep YJ - Dual 35 spline D60's, 39" Krawlers, and some deep gearing
1tondodge
smoke screw?
Postby Philip » Wed Jul 09, 2008 8:52 am
Guy's he is showing a 89 model truck in his sig. That is a nonIC'd engine. The HX35 uses a flange fitting for the outlet pipe hookup. His engine uses a cross over tube that uses a hump hose connection. His turbo also uses a 3" inlet hose.
Some mods will be in order to hook the HX35 up to his stock intake tube setup.
Postby dpuckett » Wed Jul 09, 2008 8:53 am
1tondodge- welcome to 1stGen.
The nonIC trucks had a smaller inlet than the latter, IC'd trucks, so it isnt a direct fit, but can work with some fab work.
I'd recommend an intake elbow from a junkyard 5.9- maybe a Freightliner or Ford- and a turbo outlet elbow from the same type truck. Put some pipe and silicone hose between the two, and you're set to go. Bgilbert has the part numbers for the right-left facing elbows.
Daniel
Postby 89silverbullet » Sat Jul 12, 2008 2:13 pm
I am running the bhaf so it would not be difficult to run the 4" intake but I do have a little bit of a challenge ahead of me is what yall are saying.
89silverbullet
Postby rbrettctd » Sun Jul 13, 2008 11:09 am
Go to member endeavors and check out my custom crossover I built to adapt the hx35 before I intercooled my truck. (Good way to push a scary 47lbs boost and make the turbo scream!)
Randy
rbrettctd
Postby 89silverbullet » Sun Jul 13, 2008 1:33 pm
rbrettctd how much woud it be to get one to me?
89silverbullet
