RUNNING BAD
RUNNING BAD
Postby cummins king » Mon Aug 04, 2008 8:26 pm
The last couple of day the truck has been running weird.
As soon as i get on the pettle, and try and biuld a bit of boost the etgs go way out of control, and the turbos lag badly. I can only hit 25 maby 30 psi witch is half of what i was doing before and the etgs are at 1600+ ,and i didnt make any changes. Its blowing alot of back smoke, more then before, and maby abit of white smoke just before the black smoke.
Before i could hit 50 pounds, and not even break 1250d.
now it 25 - 30 pounds and 1600+.
Any thoughts?
Joel
93 4X4 auto
cummins king
Postby gear jammer 91" » Mon Aug 04, 2008 8:40 pm
I'm not any where near as into these trucks as you are, so if you've already checked what I can come up with, thats why.
Could one or more of your injectors have gone bad?, somehow have a clogged nozzle or something?
I'm sure you've checked but there's the possibility of boost leak.
Blown out intercooler?
If that's not it try some of those new platinum plus 4 spark plugs, I hear they make a lot of power. :lol:
01 LB7
gear jammer 91"
Postby railhor5.9 » Tue Aug 05, 2008 9:54 am
maybe your injectors arent poppin off right just dumpin fuel in makin white smoke.... just a thought... see if your turbo spins freely then check your boost boots and tubes
1993 d250,single cab short bed, sbc, 175hp p-pumped,4kgsk,370's, fass 150. hx35
1997 2500 4x4 , 913,191's,3kgsk,5x16, 3rd gen dubs.
railhor5.9
Postby cummins king » Tue Aug 05, 2008 4:27 pm
Injectors were fine, but it doent mean they still are, i think the very ittle bit of white smoke is just my leaking top turbo, that i havnt got arount to fix.
I think its a boot to, i stil havent finnished the twins yet and theres just a patch job booting system in there now so it wouldnt suprize me if that was the answer,
Buts its amasing how a little boot issue can make such a difence
93 4X4 auto
cummins king
Postby PToombs » Tue Aug 05, 2008 5:37 pm
Either that or the I/C popped. Just whip up a tester and throw the pressure to it. You should be able to hear it leaking if you lost that much.
Postby cummins king » Tue Aug 05, 2008 5:42 pm
PToombs wrote:Either that or the I/C popped. Just whip up a tester and throw the pressure to it. You should be able to hear it leaking if you lost that much.
Hey Pete, read my sig....... :lol: No ic,
93 4X4 auto
cummins king
Postby PToombs » Tue Aug 05, 2008 5:47 pm
DUH! :oops: :bh: Well, that cuts down on the spots it can leak, huh?
:jumpsmile:
Postby cummins king » Tue Aug 05, 2008 8:15 pm
a Ya :lol:
93 4X4 auto
cummins king
Postby GO OVRIT » Tue Aug 12, 2008 8:34 pm
Did you ever put a good fuel filter in the system?
GO OVRIT
