timing???
timing???
Postby 1991cummins » Wed Aug 13, 2008 5:17 pm
hey guys...
i want to advance my timing... but... umm :oops:... i dont really know what i am doing... i know it has to do with physically advancing the pump, similar to advancing the timing on a gasser with a distributer... right??? but i dont know what to do...
any info would be great....
thanks a bunch
1991cummins
Postby PToombs » Wed Aug 13, 2008 5:27 pm
Loosen the 3 bolts that hold the pump to the timing cover, loosen the one on the bottom, rear. And I like to loosen the lines, so they don't have strain on them. Push the top of the pump towards the head about 1/8 of an inch. Tighten the bolts and lines. Simple. :roll:
Sometimes the pump moves really hard. I put big channel locks on mine to twist it. I might have used a 2x4 to pry with on another one. ;)
Postby 1991cummins » Wed Aug 13, 2008 5:33 pm
all i need is an eigth of an inch??? thats nothing... how far do i have till i hit the block? and how much of a difference should i notice???
1991cummins
Postby aspoonhour » Wed Aug 13, 2008 5:51 pm
I was going to try this when I was doin' the other stuff this weekend, but I decided to wait until I have the time to tidy up the wiring that seems to be all over the place. Plus I need to find a wrench to get to the nut near the block.
Let us know how it goes!
aspoonhour
Postby 1991cummins » Wed Aug 13, 2008 5:58 pm
i didnt look too hard... but i only saw two nuts... i felt around on the backside but couldnt feel anything interesting... how hard is it to get to???
1991cummins
Postby PToombs » Wed Aug 13, 2008 6:00 pm
1/8th is quite a bit! There is about 1/2 inch to the head, most trucks are different. You will notice reduced EGT's, reduced boost, less smoke. But the truck will be quicker, and faster.
I never did figure out the whole " x degrees = how much mm of spill port" thing.
Postby 1991cummins » Wed Aug 13, 2008 6:18 pm
ok cool... i am going to try the upgrade this weekend... tell yall about it later...
1991cummins
Postby aspoonhour » Wed Aug 13, 2008 6:23 pm
Not sure that this pic will help, but maybe it'll help you envision where the 3rd one is.
I've read that it takes "U" shaped wrench. I'm sure someone has a pic a some info about it.
aspoonhour
Postby 1991cummins » Wed Aug 13, 2008 6:33 pm
wow ok awesome... that pic helped a bunch thanks... why is the pump so freakin hard to turn... and is there another bolt on the other end of the pump right next to the shut off sylonoid??? cause it looks like there is but it might not be necisary to loosen up...
1991cummins
Postby aspoonhour » Wed Aug 13, 2008 6:46 pm
My trucks all have brackets near the inj lines. I think you can loosen it fairly easily. Just one bolt. Outside of that, inj lines, and maybe the main fuel supply line. It's probably not helping. There is a coupling up under there, that might make it easier if you loosen it too!
Good luck!
aspoonhour
Postby PToombs » Thu Aug 14, 2008 5:39 pm
The 4th bolt is on the rear of the pump. See the bracket that bolts to the pump head, just outside the lines? The bolt is on the bottom of that.
Sometimes they turn harder than a SOB. That's why I used a board on mine, more leverage.
Postby skilletky » Fri Aug 15, 2008 4:17 am
you will most probably need a s shaped wrench to get to the bottom bolt, that s the only was i could get to it. i tried the u shaped wrench but that didn't work. i just advanced my pump yesterday and could tell a big difference. feels much quicker .i lost about 3 psi of boost and the egts were considerably lower. i got the pump really really close to the head, to where you can't fit yer pinky finger between them. is that a little too much?
skilletky
Postby 1991cummins » Fri Aug 15, 2008 8:50 am
thet were telling me an eigth of an inch from stock... as im sure you have read lol :lol:
are there any marks on the pump to show you where stock settings are... my pump has been replaced and i want to make sure its at stock before i advance it any??? :sad:
1991cummins
Postby Begle1 » Fri Aug 15, 2008 10:43 am
The stock timing marks are on the left-most bolt; there's a line on the IP flange and a line on the timing case. The idea is to move the IP so that the IP line is 1/8" above the timing case line.
Postby skilletky » Fri Aug 15, 2008 12:30 pm
my pump had been replaced for the recall, the pump on there now dose not have a timing mark on it, so i don't know if it was set at stock to begin with. i have seen a few other truck around these parts like this.
skilletky
