So what do you guys think should be my next step? I already install a boost gage. I know that I need a pyro but should I wait till I do my exhaust? What do you guys think? And what kind or should I say brand is best.
Thank you for the info.
Escoria
PToombs wrote:No need to remove the manifold. If you try that, you may be removing broken manifold bolts from the head. Not fun!![]()
Drill just in the back half of the manifold before the turbo. The manifold has a web in the middle, you won't like the result of that. If you search, you can find pics. Grease the drill bit, then grease the tap. When done, reach in the hole with a magnet and get the last of the shavings out. Anything left will be so small it won't hurt the turbo or anything.
