16cm or 18cm?
16cm or 18cm?
Postby peobryant » Sat Oct 25, 2008 3:45 pm
I need to get rid of my 21cm housing, but am stuck on whether or not to buy a 16cm exhaust housing, or an 18cm.
The mods I plan for the truck are, 366 Spring, Maxed pump, DennyT stage II fuel pin, and injectors. (Either POD's or 6X12's)
What housing would run best with that setup?
Thanks for any help
Re: 16cm or 18cm?
Postby TWorline » Sat Oct 25, 2008 5:59 pm
'91 Cummins wrote:I need to get rid of my 21cm housing, but am stuck on whether or not to buy a 16cm exhaust housing, or an 18cm.
Thanks for any help
If you plan on maxing the pump with the above injectors(I would go with the 6X12's rather than the POD injectors) the exhaust housing really will not matter that much on a stock turbo as you will not be able to keep it cool. With my setup and a HX35 with a 16cm2 housing my truck would hit 1600 degrees 1/2 way through 5th. gear when running it through the quarter.
Tim Worline
http://www.CoolerTubz.com/
TWorline
Postby cedardiesel » Sat Oct 25, 2008 6:44 pm
hey definately go with a 14cm2 cause I got the 16cm2 it helped a whole lot goin from the 21cm2 but it still doesn't have quite the spool I was looking for its slow get to bout 5lbs but it then after that lights pretty quick it's just slow gettin to 5lbs
90 W250 4x4 5spd pump Ve cranked wide open, BHAF, HX35 with all 2.5" intake piping, and 4" straight piped
92 W250 4x4 5spd P-pumped B1B over B2 are on and now slippy clutch
cedardiesel
Postby peobryant » Sat Oct 25, 2008 11:46 pm
I have an automatic though, you have a 5spd. The manual tranny trucks seem to like smaller exhaust housings more than the autos. I'll probably go with the 16cm.
Thanks for all the help
