New Cross flow head
New Cross flow head
Postby mhuppertz » Sat Dec 27, 2008 11:02 pm
I'm working on a solid model for an new, cross flow head for the Cummins, and I need the exact head bolt spacing and cylinder bore centers and spacing for the 5.9. Any of you out there have blueprint specs????
Mark
mhuppertz
Postby Redneckintraining » Sun Dec 28, 2008 4:49 am
I thought it was crossflow?the intake manifold is on the other side of the exhause manifold.
Redneckintraining
Postby mhuppertz » Sun Dec 28, 2008 10:15 am
Redneckintraining wrote:I thought it was crossflow?the intake manifold is on the other side of the exhause manifold.
The valves are in line with the head. I want to put the valves perpendicular with the head and use high ratio rocker arms.
mhuppertz
Postby KTA » Sun Dec 28, 2008 10:26 am
You might want to think some more on how that is all going to work. High ratio rockers is going to be pretty tough when your intake is right next to your pushrod. If you did it conventionally your rocker would have to be very small with a very small piviot shaft. The stock ones flex a bit already with good springs, making it smaller and higher loaded from extra ratio wouldn't be a good idea I don't think. If you want to build a head make it a 3 valve with 2 decent sized intakes and 1 big exhaust. Then center the nozzle and use 24v style pistons. 8)
Postby 75Dodge » Sat Jan 03, 2009 5:18 pm
That is an interesting idea... I like it. Similar to what Ford did to their modular cylinder heads. But what would be the advantage of the 3 valve design vs. a 4 valve head? Isn't that one pretty efficient? Especially being turbocharged.
1989 D-250 LE Automatic 150hp at 55mph! 3200K Spring, tweaked pump, H1C/H1E hybrid.
75Dodge
Postby mhuppertz » Sun Jan 04, 2009 9:30 am
75Dodge wrote:That is an interesting idea... I like it. Similar to what Ford did to their modular cylinder heads. But what would be the advantage of the 3 valve design vs. a 4 valve head? Isn't that one pretty efficient? Especially being turbocharged.
More valves give you more flow at less lift with less shrouding. The downsides are weaker head, more friction, more parts. I need to study a four valve head. I really like the three valve idea though for a turbocharged engine. Pretty sure I could build a high port, retro fit head...
mhuppertz
Postby mhuppertz » Sun Jan 04, 2009 4:07 pm
KTA wrote:You might want to think some more on how that is all going to work. High ratio rockers is going to be pretty tough when your intake is right next to your pushrod. If you did it conventionally your rocker would have to be very small with a very small piviot shaft. The stock ones flex a bit already with good springs, making it smaller and higher loaded from extra ratio wouldn't be a good idea I don't think. If you want to build a head make it a 3 valve with 2 decent sized intakes and 1 big exhaust. Then center the nozzle and use 24v style pistons. 8)
I don't know, have you seen the rat trap on top of a 24 valver? I can't do any worse than that!
mhuppertz
