injectors
injectors
Postby fasttalker83 » Thu Feb 12, 2009 8:08 pm
I need the part numbers for bosch 6x15 and 6x18 tips if anyone has them around it would much appreciated
fasttalker83
Postby KTA » Thu Feb 12, 2009 8:49 pm
There are no such Bosch tips. They have to be custom made.
Postby Ramrod90 » Sat Feb 14, 2009 3:10 pm
You could go onto New Era diesel or call up Scheid diesel to get some custom honed to that size. I am currently running New Era 6x18's. They ran me about $700
Ramrod90
Postby peobryant » Sat Feb 14, 2009 9:11 pm
Ramrod90 wrote:You could go onto New Era diesel or call up Scheid diesel to get some custom honed to that size. I am currently running New Era 6x18's. They ran me about $700
How do you like those New Era's? I was thinking about getting a set myself, but not 6X.018's more likely 6X.012's or something like that.
Postby Richie O » Sat Feb 14, 2009 9:25 pm
I am really looking at the 435's. I hate the idea of turning in my stockers for cores. I think for 175 bucks I would be better off keeping my stockers in case I want to switch back. Its only money.
Postby Ramrod90 » Sun Feb 15, 2009 1:11 am
I like them a lot. The problems that I face is that on a hard run, I can pull my stock LP down to 0psi. I am also still running my stock turbo so egt's can get a little wily. You can run these injectors on a pretty much stock IP and the egt/fuel pressures will be manageable, I have my pump maxed out (that's my problem) but I would recommend these to anyone on the road to HP. Best part is, even if you get up to 500 or 600 hp, you still don't have to get a bigger set. OOOH and by the way, with these injectors and my IP settings, I can blot out the sun if I so choose (which I always do) :lol:
Ramrod90
Postby PToombs » Sun Feb 15, 2009 6:39 pm
Richie, go to the local pump shop and buy a set of cores. I did that and they only charged me $60. Or post for a set of cores on here, you should be able to get them for less than a $100.
Postby Richie O » Sun Feb 15, 2009 6:40 pm
PToombs wrote:Richie, go to the local pump shop and buy a set of cores. I did that and they only charged me $60. Or post for a set of cores on here, you should be able to get them for less than a $100.
Will look into that.
