Air?
Air?
Postby 93 welding rig » Mon Feb 16, 2009 6:20 pm
hey guys, checkin oil, fluids and such over the weekend, decided to check out the air filter. there is just a little opening to get air in the box. i mean a small opening. looked for an intake kit for my 93 intercooled.....needle in a haystack mean anything? any suggestions? can you take a dremel tool to the box to open it up anymore? can you connect a different filter directly to the tube? im sure she wants to breathe more air than shes a gettin. :?
93 welding rig
Postby TWorline » Mon Feb 16, 2009 6:23 pm
Mad Max here on this site makes an intake: http://www.asamodifieds.com/
Tim Worline
http://www.CoolerTubz.com/
TWorline
Postby 93 welding rig » Mon Feb 16, 2009 6:39 pm
wow that was a quick response! thanks, and the price is cheaper than i thought it would be. im assuming the kit comes with everything?
93 350 2wd club cab straight piped with asa intake
93 welding rig
Postby peobryant » Mon Feb 16, 2009 6:39 pm
TWorline wrote:Mad Max here on this site makes an intake: http://www.asamodifieds.com/
Does anyone have any experiance with that intake? Or is it better to just build one? If I should build one, what would be the best way to do it? (Materials and such.)
Postby Richie O » Mon Feb 16, 2009 6:45 pm
I just cut the opening bigger then fabbed a cold intake from the core support to get some fresh air.
cheap, but thats my middle name.
Postby 93 welding rig » Mon Feb 16, 2009 6:56 pm
cheap is such a bad word....... inovator, inventor, get-er-done even. could you tell a big difference or a slight difference?
93 welding rig
Postby Richie O » Mon Feb 16, 2009 7:04 pm
I will stick with " CHEAP ". I once took a few hours making a valve spring compressor tool so I could replace valves in a industrial 391 FE ford.
Anyway, as far as did I see any improvement?? Who knows. I think at stock settings the factory size is ok. I had already pulled the piece that goes between the housing and the core support a few years ago. A buddy of mine was putting on a 16 cm housing and I also bought a K N filter from his shop. He said that had to go so we ripped it out.
Postby randyswelding » Mon Feb 16, 2009 8:44 pm
i like my asa intake i think it makes the bay cleaner lookin.i got the black one and since everything else is black it makes it look good
randyswelding
Postby pulltilbroke » Mon Feb 16, 2009 9:55 pm
I got an asa on my truck, but you could make somthin cheaper
Postby peobryant » Mon Feb 16, 2009 10:01 pm
randyswelding wrote:i like my asa intake i think it makes the bay cleaner lookin.i got the black one and since everything else is black it makes it look good
Do you have to run a special filter with the ASA? If so what kind?
Thanks
Postby Mad Max » Wed Feb 18, 2009 8:34 am
Each Intake comes complete with an big AFE 4" filter. No custom work is required for the kit to bolt in place - takes about 1/2 hour ;) .
- Sam
ASA Mods
"...there's always a way".
'78 W950 Power Wagon "Bud"
'85 W350 Crew "Big Mack"
Mad Max
Postby Farmboy » Wed Feb 18, 2009 9:09 am
I just took the box off and zip tied the stock filter to the fender. pretty redneck but it will do untill I can get a mendrel bent tubing intake on with a conical filter on the end. ;)
Farmboy
Postby OLDEARL93 » Sat Mar 07, 2009 10:15 pm
what I did is I got an oil based filter and I removed the original cover and drilled inch and a half holes all over it and put it all back and only spend 65 dollars ond the air oil filter I do have to keep the filter maintaned but that is all, what they sell you is no better but it does cost you 200 plus dollars
93 4X4 EXTRA CAB 5 SP. GERT.EGT,BOOST ,RPM GAUGE,TIMMING AD,PUMP TWEEKED,NEW HX35,REST STOCK
OLDEARL93
Postby Richie O » Sat Mar 07, 2009 10:29 pm
OLDEARL93 wrote:what I did is I got an oil based filter and I removed the original cover and drilled inch and a half holes all over it and put it all back and only spend 65 dollars ond the air oil filter I do have to keep the filter maintaned but that is all, what they sell you is no better but it does cost you 200 plus dollars
Also know as the swiss cheese air box. It will work.
I at some point want to plumb up a hood scoop. It would sound good if the turbo was screaching through a working scoop. :)
Postby 93 welding rig » Thu Mar 12, 2009 6:50 pm
Didnt have much of a choice on getting the cold air intake kit.... tube from turbo to air box cracked right out from the turbo.... waiting on it to come in the mail..... looked good in the pics i seen.
93 welding rig
