I/C "horns" forward, OK?
Postby ontos » Tue Feb 17, 2009 5:05 pm
This is on a 89 non I/C 1stgen in a front engine Motorhome on a freightliner chassis.
Have 1stGen I/C to install. No way to get by the radiator on the sides. Easy to go over the top if the horns are facing forward. I did sleep through physics class, but it dosen't seem to be a problem to do it that way. A few elbows and done.
Thought I better check with some smart people before I go ahead, Thanks any info or opinions.
J Golden
PS: I could have just asked Pete Toombs but I owe him a bunch of beer already.
89 5.9 non IC Freightliner motorhome Chassis 545 Allison
ontos
Postby Redneckintraining » Tue Feb 17, 2009 5:32 pm
the way you have it plumbed doesnt matter as long as it connects the turbo to IC to the intake,with as little of a restriction as possible.
Redneckintraining
Postby PToombs » Tue Feb 17, 2009 6:14 pm
Cheapskate! Figure it out for yourself! :x
And I thought the Irish were generous with their booze! :P
:jumpsmile:
Postby bgilbert » Wed Feb 18, 2009 5:40 am
You'll need a forward facing intake horn. Or build it to suit;). The 91.5-93 intercooled 1st gen horn will only point left or right, not forward or back.
Bill Gilbert
Postby ontos » Wed Feb 18, 2009 9:40 am
My existing non I/C intake has a simple stub comming up and I should be able to use the same connection used for the crossover pipe, when I get that far.
Now I'm trying to locate 90* elbows that will take me up and over the I/C I have.
Thanks.
ontos
Postby ontos » Wed Feb 18, 2009 9:42 am
PToombs wrote:Cheapskate! Figure it out for yourself! :x
:jumpsmile:
Pete,
Relax, I have a vintage case of Utica Club I'm saving for you.
Redneckintraining: Thanks for the reply.
ontos
Postby CumminsPride » Wed Feb 18, 2009 12:56 pm
Go to intakehoses.com for your piping needs or those ( rice burner kits) intercooler kits off ebay maybe cheaper.
06 3500 AT Mega Cab SRW 4X4
CumminsPride
Postby ontos » Fri Feb 20, 2009 12:41 pm
Thanks folks.
I got steele elbows bent at a shop. looks like they will work .
ontos
