What should I do
Postby pulltilbroke » Wed Mar 04, 2009 1:27 pm
A stock auto isn't faster.
I am not to worried about goin fast as I would keep it stock.... ish
But I just like sticks better and its easier putting a 4500 in a stick truck
Wow this thread got derailed quik, fast and in a hurry
Postby lectro_static » Wed Mar 04, 2009 7:37 pm
well I think I will get the 370s after I get my EGT, boost and 4" exhaust in. Then a denny t fuel pin and Im still not sure on which turbo to look for, the hx35, hx40 or s300. I want a fun to drive truck but something that isnt crazy and still gets decent mileage. I am getting 22 - 26 mpg right now, well I was until I found I could shoot a black cloud at bicyclists that opt to ride in the middle of my lane.
BTW, guy in Shelton WA. has/ had a 1992 ex cab dually 5sp was asking $1500 for it, needs a tranny....... found it on craigslist a week or two ago. I cant remember if it was two or four wheel drive tho.
Is there a recipe for doing "x" gives you ____ hp and ____ torque? I know that nothing is concrete but something that will get me close.
Thanks
weeping head gasket
4" straight pipe
M&H M3 fuel pin
M&H Dynamic Timing Advance
366 spring
Auto Meter EGT and Boost
lectro_static
Postby peobryant » Wed Mar 04, 2009 7:54 pm
lectro_static wrote:well I think I will get the 370s after I get my EGT, boost and 4" exhaust in. Then a denny t fuel pin and Im still not sure on which turbo to look for, the hx35, hx40 or s300. I want a fun to drive truck but something that isnt crazy and still gets decent mileage. I am getting 22 - 26 mpg right now, well I was until I found I could shoot a black cloud at bicyclists that opt to ride in the middle of my lane.
Thanks
370's are a good choice in injector. PToombs almost has 400rwhp out of his set. I'm in the same turbo boat as you, and have narrowed it down to 3 (I think), but I'm thinking a 62/71/14 is what I'm going with.
If that '92 Dually has a rust free body, and strong running engine, I would jump on that thing. $1500 is a real good deal, especially for a rust free truck.
Postby SChandler » Thu Mar 05, 2009 9:33 am
lectro_static, welcome to the site! For towing, 370's, an HX40 from PDR or HTT, full 4" exhaust (talk to Source Auto in Milwaukie for a 1st gen HX40 downpipe), and minor to no pump adjustments will get you close to 300hp and be very towable (i.e. doesn't go to 1500* every time you think of going up a hill loaded). There are a couple of members on here that have that combo and do well towing. You could PM member KTA, he has this build on his towing truck and it works well for him grossing 20k+.
Not on topic: There are some of us from this site meeting at PIR on March 21st for the NHRDA race. You should bring your truck down. It will be a good time. See thread here: http://www.1stgen.org/viewtopic.php?t=2706&start=75.
SChandler
Postby lectro_static » Thu Mar 05, 2009 5:06 pm
Where can I get a 366gsk locally? If you guys are going to be doing one, well............ LOL
Whats different about the hx40 down pipe? I worked at Tube Specialties and American Metal, both do mandrel bent exhaust, I have a bunch of 4" here at home and am planning on doing my exhaust this weekend, well weather permitting of course.
Hillsboro huh? Im out there at the shop almost every weekend....
weeping head gasket
4" straight pipe
M&H M3 fuel pin
366 spring
lectro_static
Postby peobryant » Thu Mar 05, 2009 9:52 pm
lectro_static wrote:Where can I get a 366gsk locally? If you guys are going to be doing one, well............ LOL
Your local Bosch pump shop should have the 366 spring. If not, they are all over the internet.
The HX40 downpipe is 4" instead of the stock 3". The stock turbo will still have a 3" outlet, so I'm not sure if you even really need the 4" downpipe. If you swap to a bigger turbo, most aftermarket outlets are 4", so you will need it then.
Postby Richie O » Thu Mar 05, 2009 10:12 pm
Here is a pic of the difference between 3 and 4 inch downpipe.
Postby peobryant » Thu Mar 05, 2009 10:41 pm
Richie O wrote:Here is a pic of the difference between 3 and 4 inch downpipe.
With the stock turbo, would the 4" downpipe even matter?
Postby SChandler » Fri Mar 06, 2009 12:32 am
Source Automotive has them. Rip and his crew are good guys to deal with, they'll treat you right. I've bought parts from Cummins NW on Swan Island and had good luck with them. I needed parts for my injection pump and they sent me to a shop on Vancouver Way, east of I-5. I can't remember the name of the shop, but I went in and told them what I needed and they got the parts for me pretty quick.
Since you've got all the pipe, the only other thing you need is a v-band flange. You'll need a 3" one for the stock turbo and a 4", HX-40 style for an aftermarket turbo.
Yep, Hillsburrito. I'd be happy to help you do the spring, but it won't be at my place since I live in an apartment complex. They get so testy about working on vehicles in the parking lot. :roll:
SChandler
Postby lectro_static » Fri Mar 06, 2009 5:53 am
Source said they have them on the shelf and couldnt remember an exact price but they want less then $30. I will try to pick one up next week and depending on how things go maybe install it next weekend.
4" exhaust will be better, atleast thats what a couple places here have told me, 3" out of the turbo and right after the band clamp ramp it up to 4". Then when I get a new turbo its just the first couple inches Ill have to change.
We have a shop in Hillsboro, the DG Industrial park, on Witchhazel, you anywhere near there? If so we are out there Sundays building sandrails and bajas we could change the spring there if you want to help out.
weeping head gasket
4" straight pipe
M&H M3 fuel pin
366 spring
lectro_static
Postby SChandler » Fri Mar 06, 2009 9:28 am
When I bought mine, I think it was listed at $28 or something like that but they were going to give it to me for $20 cash.
I'm up by 185th and Evergreen. I'd like to help Sunday, but my fiance and I are supposed to be meeting with the minister Sunday early afternoon and then dinner with my fiance's mom Sunday evening. :(
SChandler
Postby lectro_static » Fri Mar 06, 2009 4:17 pm
I meant NEXT weekend, the 15th, this weekend is get my baja on wheels and get sandrail turbo motor cracked off.......... well I hope
weeping head gasket
4" straight pipe
M&H M3 fuel pin
366 spring
lectro_static
Postby Richie O » Fri Mar 06, 2009 5:09 pm
It is supposed to make a difference.
Postby lectro_static » Fri Mar 06, 2009 6:15 pm
I have heard that it will help lower EGT's and make more power. I honestly dont know if it will or not, I have the stuff may as well use it and when I get the new turbo all I will have to do is cut the 2" off and add the new flange.
Where is the best place to get the boost reading from, right at the elbow out of the turbo or after the i/c? I have my truck torn apart now and want to get it installed.
weeping head gasket
4" straight pipe
M&H M3 fuel pin
366 spring
lectro_static
Postby Richie O » Fri Mar 06, 2009 6:18 pm
I put mine in the intake on the motor. I got one of the boost tap bolts that replace one of the intake plate bolts.
