3/8" Fuel System Questions
Postby RSWORDS » Fri Feb 27, 2009 1:54 pm
Getting ready to pull the trigger on my 3/8" fuel system and have some questions...
Here is were I'm at so far...
Got a draw straw...
http://www.vulcanperformance.com/Draw-S ... p/dsii.htm
Got a Walbro 392 and 20' of 3/8" Fuel line.
What kind of fitting (thread size) should I get for the pump? Any GOOD pics?
I need to get a pre-filter for the pump seeing as how I am going to lose the sock in the tank. Any Ideas? Some sort of screen is what I need I guess...
Also I'm by-passing the stock pump. I have a SBC fuel pump block off plate and I've heard it will work but would anything be hurt by just leaving the stocker in with out the lines hooked up? Would it burn up or something?
Gonna run this off a relay. Is there a key on power source under the hood I can use to trigger the relay?
Any other tips? Gonna start on this next week and would like to have everything I need.
thanks!!!
RSWORDS
Postby Ace » Fri Feb 27, 2009 2:17 pm
You're gonna need a regulator for the return line off the Walbro.
Postby RSWORDS » Fri Feb 27, 2009 2:35 pm
Ace wrote:You're gonna need a regulator for the return line off the Walbro.
Forgot that one... I have it
RSWORDS
Postby fergavs » Fri Feb 27, 2009 6:41 pm
just use the ignition wire under the column to trigger your relay. I actually use it to trigger a relay to turn on a bunch of relays on my truck. lol.
fergavs
Postby RSWORDS » Sat Feb 28, 2009 2:58 pm
What size fitting am I going to need to go into the fuel filter, out of it, and into the injection pump? they are not NPT are they? I wanna say Iremember soem one saying 12mm or something
Thanks
RSWORDS
Postby Ace » Sat Feb 28, 2009 3:14 pm
I would lose the stock filter and get something bigger/better/more flow as long as you are basically redoing the whole fuel delivery system anyway. Otherwise you are still pushing fuel through 5/16" lines, even smaller passages where it flows through the manifold and a pretyy small 10um filter itself. You would have to either adapt some sort of clamp-on fitting for the existing lines or get banjo barbs or bango flare adapters for hard lines for the stock filter. Don't know where to get those. Parker probably makes something that will thread in there and seal with one of those rubber/brass washers like comes in the big line kits.
The Wix 33411 I'm running is rated at 5um nominal, screws into a head with 1/2" ports and will easily flow more fuel than anyone will ever burn in a 5.9:
http://stuff.is-a-geek.net/PhotoAlbum/C ... TD_123.jpg
Postby RSWORDS » Fri Mar 06, 2009 7:33 pm
Alright... Gonna tackle this this weekend...
I'm coming out of the fuel tank with a Draw-Straw pre-Filter just before the Walbro which will be within the first 2 or 3 feet of the line. Then the fuel pressure regulator then I have a filter/water seperator then going to this port on the injection pump...
Is this correct? What size fitting is that in the top of the pump?
Any other sugestions?
Thanks!
RSWORDS
Postby PToombs » Fri Mar 06, 2009 7:40 pm
I can't actually help on size, but I have a suggestion. My buddy put on an Airdog, and the fitting they gave him was a 90* that screwed directly into the pump. Take that adapter out, put in the 90, and it should stay below the throttle lever. Then the rest of the plumbing went from there.
He did tell me what size and thread the hole was, but I don't remember. :oops:
Postby GO OVRIT » Fri Mar 06, 2009 9:25 pm
Switch the order on the regulator and the filter.
GO OVRIT
Postby Ace » Sat Mar 07, 2009 8:43 am
Why?
Postby RSWORDS » Sat Mar 07, 2009 8:43 am
GO OVRIT wrote:Switch the order on the regulator and the filter.
OK
RSWORDS
Postby RSWORDS » Sat Mar 07, 2009 8:44 am
PToombs wrote:I can't actually help on size, but I have a suggestion. My buddy put on an Airdog, and the fitting they gave him was a 90* that screwed directly into the pump. Take that adapter out, put in the 90, and it should stay below the throttle lever. Then the rest of the plumbing went from there.
Thanks Pete, Thats what I was thinking of doing. Do your remember if it is a normal NPT size or something odd?
RSWORDS
Postby fergavs » Sat Mar 07, 2009 12:31 pm
I believe it is a 12mm fitting. If not it will be a 14mm.
fergavs
Postby PToombs » Sat Mar 07, 2009 3:08 pm
Metric straight thread. 12 or 14 like Fergavs said. I think it's 12mm, but don't hold me to that.
Postby RSWORDS » Sat Mar 07, 2009 9:34 pm
So do they make an adaptor that uses those threads or must I get creative?
RSWORDS
Users browsing this forum: No registered users and 67 guests
