Fuel screw
Fuel screw
Postby 2wd_sled_puller » Mon Mar 09, 2009 6:49 pm
Anyone have one available that i can by off you. i guess someone eles tried to do pump work to this thing before i bought it and they cross threaded the fuel screw
The HULK 1993 dodge cummins Afc work. Screw turned to runaway. Ht3b turbo looking for sticks
Piper 1997 chevy 2500 vortech 350 soon to be vortech 383
2wd_sled_puller
Postby TWorline » Mon Mar 09, 2009 7:01 pm
You may need a pump top as well, check your threads carefully.
Tim Worline
http://www.CoolerTubz.com/
TWorline
Postby 2wd_sled_puller » Mon Mar 09, 2009 7:11 pm
That looked ok. Only thing messing me up is the screw. I can get it started. Once in get it in so far say about where stock is it gets hard as hell to turn. And i got all the stoppers ground off.
2wd_sled_puller
Postby gear jammer 91" » Mon Mar 09, 2009 7:41 pm
The threads on my fuel screw were messed up where the tack welded lock collar was. I had to chase them with a nut and clean them up before my fuel screw would go in very far past stock.
01 LB7
gear jammer 91"
Re: Fuel screw
Postby SChandler » Tue Mar 10, 2009 9:07 am
2wd_sled_puller wrote:Anyone have one available that i can by off you. i guess someone eles tried to do pump work to this thing before i bought it and they cross threaded the fuel screw
If you can't find anybody with an extra, you can get them from your local Bosch injection dealer. If you search for fuel screw on here, member Begle1 broke his one time. I think he posted the part number for it somewhere (maybe the Engines section).
SChandler
Postby PToombs » Tue Mar 10, 2009 3:51 pm
The screw can't go all the way in you know. There is a shoulder in the top that the o-ring seals against. You should measure down and see if you are bottomed out against it.
Postby gear jammer 91" » Tue Mar 10, 2009 4:35 pm
I meant to mention that too.
01 LB7
gear jammer 91"
Postby 2wd_sled_puller » Tue Mar 10, 2009 4:41 pm
i tryed looking for part number no luck can someone give me a hand
2wd_sled_puller
Postby A_port93 » Tue Mar 10, 2009 10:45 pm
Fuel Screw Bosch # 1 463 402 423
i got that on here i dont know if that is correct
93 w250 getrag 220k 60/12wg over an ht3b/26 and ddp sticks, south bend ofe
A_port93
Postby 1stgencummins » Fri Mar 27, 2009 6:30 pm
from previous experiences I found that if you run a tap down in to to clean the threads up you will know for sure that the threads in your pump are good when you put your screw in. if im wrong someone please correct me.
1stgencummins
