MudSlinger79 wrote:What should i set the regulator at?
DTanklage wrote:you could also get a softer spring from carter instead of a $200 reg from jegs
2nd gen lp's are nice cuz they have a larger bore and better fittings than the p/n cummins recommends for the first gen
jmo
DTanklage wrote:yea, the one that makes 15 psi instead of 30
lol, rofl, etc
not off the top of my head but i have seen a post somewheres with the part numbers, color codes, and pressures
take it you have already contacted carter?
