S300 turbo
Postby dcube » Mon May 04, 2009 7:57 am
Thanks KTA. Would this qualify per your definition?
http://cgi.ebay.com/ebaymotors/DODGE-HX ... ccessories
Doug
dcube
Postby KTA » Mon May 04, 2009 8:13 am
That is a standard Hx40, not a Super Hx40. It is a good turbo and will still work for your application but will have a touch more lag and run a little hotter do to its lower pressure ratio.
Postby 90FIRSTGEN CUMMINS » Mon May 04, 2009 9:22 am
New era quoted me a price $1734.00 for a s300 62/71/14. Does that sound like a good price or does somone know of a better price. Also new ear was the best at answering questions that I have found so far
1990 W250 Non I/C, Mostly stock,4 inch Ex,Fuel Screw Turned Up a Little, 727TF, 366 spring, BHAF, Borgeson Steering Shaft, Under-bed B & M transmission cooler, head lights now on relays(just added)
90FIRSTGEN CUMMINS
Postby Ramrod90 » Mon May 04, 2009 10:47 am
Try this:
http://www.pdrdiesel.com/products/Custom_Built_62mm_x_12_or_14_S300_Switzer_Turbo-915-26.html
a little cheaper and I would suggest the 14cm exhaust housing for your automatic. Good luck!
Ramrod90
Postby mprmn08 » Mon May 04, 2009 5:01 pm
dont quote me on this but i was told by Adam cornell from central michigan performance diesel that he could get me one for about 1000. this was about 1-1 1/2 months ago so like i said DO NOT quote me on this. his number is 989 621 9806 if you wanna give him a call. if you call during the day he may not answer cause he does have a regular job and does diesel performance on the side.
mprmn08
Postby mprmn08 » Mon May 04, 2009 5:03 pm
incase anyones wondering also adam told me he could EDM my injectors for about $300-$400.
mprmn08
Postby peobryant » Mon May 04, 2009 5:11 pm
Thats a good price for injectors.
Postby DTanklage » Mon May 04, 2009 7:52 pm
if ya check the swap meet over on comp d there is a guy selling a s300 that would fit your needs perfectly
its a stocker
57/65-14
would be a great top turbo for a first gen
(and not as pricey as its bigger brothers)
don
DTanklage
Postby 90FIRSTGEN CUMMINS » Fri May 08, 2009 9:49 am
Ok so I think i have found a winner. I think im going with 62/71/13 Stainless from HTT. Has anyone had any luck or problems with these.
90FIRSTGEN CUMMINS
Postby DTanklage » Fri May 08, 2009 10:42 am
waste gate arm bent and truck would not spool until bout 2500 (with it bent)
turbo had 500 miles on it
stuck in middle of desert
ve pump and 71 turbine hope you got a lot of fuel and dont plan on towing much
hope you have a manual tranny
even with a p-pump they say stay away from 71 wheel if ya tow a lot
71 wheel is laggy but once it lites goes to max boost instantly
don
DTanklage
Re: S300 turbo
Postby DTanklage » Fri May 08, 2009 10:51 am
90FIRSTGEN CUMMINS wrote:
1990 W250 Non I/C, Mostly stock,4 inch Ex,Fuel Screw Turned Up a Little, 727TF, 366 spring(just added)
DTanklage
Postby 90FIRSTGEN CUMMINS » Sat May 09, 2009 12:39 pm
What would be your suggestion for a turbo then???
90FIRSTGEN CUMMINS
Postby peobryant » Sat May 09, 2009 1:10 pm
90FIRSTGEN CUMMINS wrote:What would be your suggestion for a turbo then???
You did say you were thinking about a twin setup right? I know a lot of second gen guys have had good things to say about an S300G (57/65/14) and an S400.
BGilbert runs an S300/S400 setup (although I think he has a 62/71/14 S300) and made over 500rwhp.
The S300G is also supposed to flow more air than an HX40.
Postby 90FIRSTGEN CUMMINS » Sat May 09, 2009 1:28 pm
Well if i cant support the 62/71/14 and keep the egts managable I would rather go with somthing else and if it is possible I would like to go with so in a year or two if I want to go with twins then I can.
90FIRSTGEN CUMMINS
Postby DTanklage » Sat May 09, 2009 1:34 pm
for what is in your sig i dont think you can beat a hx-35
not just the price either - the map of a 35 is about a perfect match for what you got
or if you want more (less heat) bd super b
the hx is 54/58
super b is 57/65
super b would work great as top turbo later but its 5 times as expensive
if it were me i would throw a 2 or 3 hundred dollar used hx-35 on it and see how i liked it
if you want more you can always sell it but i bet you love it
DTanklage
