Converting AR to CM for turbine housings
Postby fergavs » Sun Apr 26, 2009 10:00 am
I know its not exact but there was a post about approximate conversions for AR to cm when comparing turbine housings. Anybody have reference to it for me or can at least tell me the conversion? The turbo is for my twins and has a 1.08 AR. Thanks.
fergavs
Postby Richie O » Sun Apr 26, 2009 1:24 pm
Mine is .80ar and the tech at borge warner told me it equals 14.77 cm. I hated algebra but maybe some one else could figure it out. :(
Postby LOGANSTANFORTH » Fri May 08, 2009 7:30 am
Richie O wrote:Mine is .80ar and the tech at borge warner told me it equals 14.77 cm. I hated algebra but maybe some one else could figure it out. :(
*if that is true then this math should work....
14.77 divided by 80 = 0.184625.......0.184625 x 108 = 19.9395.....
or right around a 20 CM2 housing.....
*i failed math 3 years in high school so take all that with a grain of salt......
THEY PUT THEM ON A PLANE TO SOME STRANGE AND FOREIGN LAND, THEY SAID GOODBYE TO MOM AND DAD AND HELLO TO UNCLE SAM, THEY NEVER THOUGHT THE DAY WOULD COME WHEN THEY MIGHT HAVE TO KILL A MAN, THEY DID NOT SLEEP A WINK THAT NIGHT BUT THEY WON FOR UNCLE SAM
LOGANSTANFORTH
Postby beerboy81 » Fri May 08, 2009 9:22 am
where'd you get the 108?
Jake
'93 W250 LE '92 CTD/IC GETRAG 5sp. 4x4 4" lift 33x15.50x16 TSL/SX Super Swampers, Pumped up, ASA Mods, cooler tubz, 5" stacks.. 366 hiding in the glove box
beerboy81
Postby gear jammer 91" » Fri May 08, 2009 5:18 pm
The 108 he used should have been the 1.08 ar that was asked about in the first post. It threw me off too.
01 LB7
gear jammer 91"
Postby dpuckett » Fri May 08, 2009 6:25 pm
We need to know more than just the A/R ratio- we need a second number to plug in- like turbine size, overall diameter of the housing, or something like that.
Postby LOGANSTANFORTH » Sat May 09, 2009 5:52 am
like i stated......just by using my math it came to that.......but like stated i failed math 3 years in school....
LOGANSTANFORTH
