GT4088R?
GT4088R?
Postby Remps » Sat May 09, 2009 12:02 am
I was looking at the garrett site today,and at a 2.7 pressure ratio,60 lbs a minute for 425 rwhp(is what I calculated)the GT4088R with a .85 ar turbine housing looked just right on the compressor map.Will the T4 inlet flange work or would it have to be adapted somehow?I know they are expensive,I just want one. :P
Postby peobryant » Sat May 09, 2009 12:17 am
You need a T3 flange.
Postby seeker1056 » Sat May 09, 2009 4:23 am
they make T3-T4 adaptors all day long for about $29 - $69 on Ebay
Sponsors of new truck
Performance Diesel Injection
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
Postby RSWORDS » Sat May 09, 2009 6:00 am
Gonna be real laggy on the street though wont it.?
RSWORDS
Postby Remps » Sat May 09, 2009 9:02 am
I think it'll be tolerable.I don't drive around town much anyway,mostly highway.I figured it would be a good high speed/low temp turbo also.One size smaller at 425 rwhp is almost off the compressor map.I plan on buying a 4X4 and this will be my hot rod eneways. :grin:
Postby peobryant » Sat May 09, 2009 9:35 am
seeker1056 wrote:they make T3-T4 adaptors all day long for about $29 - $69 on Ebay
Just making sure he knew that he couldn't just bolt a T4 up to his truck.
Postby soggy » Sat May 09, 2009 9:49 am
You'll also need an oil restrictor and need to plumb in water lines, the ball bearing garretts are water cooled. I'm pretty sure with a 77 mm turbine wheel its going to take you a long time to spool it. the 3788r is sold as an upgrade for 2nd and 3rd gens and has the t3, and everything you need. It's a 63.5/72.5
92 W250 VE Powered
13.31@ 98.92
1993 D350 Tow Rig
soggy
Postby Remps » Sat May 09, 2009 3:08 pm
The ball bearing turbos have a built in oil restrictor.The compressor map on that 3788R looks even better then the 4088R.Wider range bottom and top.So any turbo with a T3 flange will bolt to the stock exhaust manifold?(Although if I spent the money on this turbo,I'd get a manifold too)
Postby soggy » Sat May 09, 2009 11:00 pm
http://www.xtremediesel.com/garrettpowe ... tage3.aspx
I'm sure you could find it cheaper but this is the one i was talking about.
92 W250 VE Powered
13.31@ 98.92
1993 D350 Tow Rig
soggy
Postby peobryant » Sat May 09, 2009 11:53 pm
Remps wrote:The ball bearing turbos have a built in oil restrictor.The compressor map on that 3788R looks even better then the 4088R.Wider range bottom and top.So any turbo with a T3 flange will bolt to the stock exhaust manifold?(Although if I spent the money on this turbo,I'd get a manifold too)
Yep, a T3 flange will bolt up.
