CK's Videos
Postby seeker1056 » Sat May 16, 2009 3:07 am
how far in was yur fuel screww and timing from what you were runnin on the street before you went to play on the dyno?
do you know what your timing actually is or are you guessing? - I can loan you my timing tool if you need it
I am still leanin towards runnin outa fuel somehow
Sponsors of new truck
Performance Diesel Injection
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
Postby KTA » Sat May 16, 2009 5:25 am
You have no fueling, I can not speculate as to the reason behind it, but I certainly don't think it is the injectors, I made my 627rwhp with Buddha 6x.018 so I know they will fuel. I suspect something is not right about your pump. My only guess would be that the design of the 4mm camplate shifts the position of the fuel bleed off hole so the control collar doesn't position and function right. I would suggest trying a stock camplate.
Postby KTA » Sat May 16, 2009 5:28 am
Nevermind I looked at your mods list and know the problem you have a stock governor spring!!
Postby cummins king » Sat May 16, 2009 5:40 am
I was thinking about that and nobudy broke the 500hp mark. Exept one duramax, but he had huge nirtous and he was over 1000hp
93 4X4 auto
cummins king
Postby RSWORDS » Sat May 16, 2009 8:24 am
KTA wrote:Nevermind I looked at your mods list and know the problem you have a stock governor spring!!
I think that would do it, About the time the turbo lights the pump is defueling...
RSWORDS
Postby Begle1 » Sat May 16, 2009 8:28 am
How does that explain peak power being made at a little over 2,000 RPM?
Postby seeker1056 » Sat May 16, 2009 8:29 am
there have been other posts on other sites about the 4 mm cam plate uncoverng the hole too soon - could be it
what kinda spring you got in there - you told me you were makin 38-3900 rpm on the street
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
Postby RSWORDS » Sat May 16, 2009 10:31 am
Nevr saw were the peak power was
RSWORDS
Postby cummins king » Sat May 16, 2009 3:12 pm
Ken when I got the digital rpm guage I maxed out at 3500rpm I'm guessing my crapy autometer guage dosent work well.
I do have the 3200 spring,
But ya peak power was made at 2075 rpm
And didn't buddy (sorry can't remember his name) make 501hp with a single turbo but the same pump mods?
93 4X4 auto
cummins king
Postby JAyers » Sat May 16, 2009 7:05 pm
Ck i had the same mods except a trimmed 4200gov spring, 60psi of boost ref fuel pressure, bone stock vane pump, and ksb activated . Timing was jumped one tooth and pushed next to the head. O and 6x.016's. And I had lots of extra fuel. Your deff lacking fuel. My peak power was at about 2300 rpm.
93 W250...balanced, ported, and fresh. Equipped with 14mm h/r, A1000 supply, Hamitons 188/220, T4 stainless manifold, s360/68/.91ar - s475/74/1.1ar twins, and Kennys dd clutch.
JAyers
Postby seeker1056 » Sun May 17, 2009 5:05 am
more thoughts
did you have the ksb hooked up
Giles told me that when he hooked mine up to test , fuel dropped to 30 cc's from 200cc's for whatever reason and he could not figure out why, except maybe the timing chnages dramaticaly when you have a worked timing setup.
Check your fuel shutoff and see if it dissintegrated - and plugged your deleivery valves - also happened once on my pump on the test stand
double check your regulator to make sure it isnt bypassing (stayin closed) under load for some reason - like a worn out diaphram - been there - specially when alcohol or methanol or acetone or any other rubber hating additive is used to boost your fuel - or nitro ;) ;) :roll: :lol:
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
Postby cummins king » Sun May 17, 2009 10:05 am
im thinking im going to call up Giles and get him to tell me how to mod my pump with out the governors,
shut off is gutted
no ksb, i have a plate in there with a agg. regulator
So Jay, you running boost regulated 60psi, intake pressure, at max pressure? Im setup for it i just have to plug the boost line in.
and a modded 4200 spring!
Im guessing thats where im lacking!
93 4X4 auto
cummins king
Postby Underpsi » Sun May 17, 2009 7:24 pm
Joel how do you have your afc control setup? My truck will smoke way more then that! You don't drive you truck alot just take the afc lever off you don't need to govern it and i don't think your gonna lose power by doing that either.
My truck made peak power at 2050rpm
Underpsi
Postby seeker1056 » Sun May 17, 2009 7:29 pm
oh the governor is still there - just the spring is so stiff it will never kick in because you will run outa pump ability before then
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
Postby cummins king » Tue May 19, 2009 9:04 am
i found another video, and this one you can tell i wasnt fueling at all
http://www.youtube.com/watch?v=nZdzarZOdKs
93 4X4 auto
cummins king
