converter
converter
Postby Firstgen1 » Tue May 26, 2009 6:01 pm
does anybody use a bd torque converter or even hear anything about them, they said the stall is 1600 and costs 600 dollars, sounds good to me
tell me what you think :lol:
1993 w250 pin ground, 3 turns on fuel screw, starwheel maxed, custom intake,4in exhaust, guages, 16cm housing, piston lift pump, dtt converter, shiftkit, 35 psi of boost
Firstgen1
Postby SNOOT » Tue May 26, 2009 6:46 pm
Hughes converters best bang for your buck..
http://www.hughesperformance.com/index.php
A little more money will get you a Goerend..
http://www.goerend.com/index.php
1993 W350
SNOOT
Postby dpuckett » Wed May 27, 2009 6:10 pm
I froget what my buddy has in his 93, but it bogs the engine at 1450 or so. I did a stall test on the truck when I owned it one time- engine started to pull down and REALLY drag the truck forward against the brake at 1450-1500. Mom's with a $100 stock convertor went to 2000, and I stopped the "test".
Does BD even make one for our trucks anymore? Obviously, they have one listed.......
Daniel
