dpuckett wrote:For 400hp, I'd leave it on the tooth it is.
Daniel
randyswelding wrote:ok then whats the trick for the little wedge thing on the shaft to keep it from fallin out when i put the gear on
randyswelding wrote:Ok I like the tooth jump a lot more usable power and less smoke down low until 2k then all hell breaks loose,I kicked the rear around the front of the truck I did a donut with tryin and I wiegh in at 12k that's awsone
