new manifold CNC this week
Postby seeker1056 » Thu Oct 15, 2009 9:59 am
we would never "polish" a runner - either intake or exhaust
air like any other fluid needs help to change direction without inducing stall or detremental eddies
Sponsors of new truck
Performance Diesel Injection
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
Postby ahale2772 » Thu Oct 15, 2009 11:03 am
yes agreed i was refering to fancy port and polish jobs on smallblocks, some people are convinced a polish is the best method for high horses
Postby roxxx » Thu Oct 15, 2009 8:37 pm
ahale2772 wrote:i think they are way to confident with the part...i agree its great quality but untill they can produce it efficiently and costeffictivly then they should wait till the dyno to announce it as the new massiah
True true i am kinda hoping it rocks.......... He has 7 made which kinda surprised me. steed offered me one but I have stock motor so it wont be a good run plus i have axle gremlins to sort out
1992 4x4 Reg cab LE 5 speed
4 Inch lift
Bilsteins shocks 5125
VE moderately molested
Dana 80
ultra wheel rims Type 164
ASA pipe BHAF 19037
Outerwears prefilter
A A nv4500
roxxx
Postby ahale2772 » Thu Oct 15, 2009 8:44 pm
any news on testing? has anyone actually mounted one up?
Postby roxxx » Thu Oct 15, 2009 10:02 pm
ahale2772 wrote:any news on testing? has anyone actually mounted one up?
Yes there is one mounted and it is going into dynos this weekend .it has being on the truck for 2 weeks from what i have being told
I haven't heard any results as of yet ,
4 Inch lift
Dana 80
ASA pipe BHAF 19037
A A nv4500
roxxx
Postby KTA » Fri Oct 16, 2009 6:07 am
Any plans to make a 12V version or just the 24V version like shown?
Postby roxxx » Fri Oct 16, 2009 7:14 am
KTA wrote:Any plans to make a 12V version or just the 24V version like shown?
Yes KTA . What I need is a 1 st gen manifold so he can see if there is any real differences , If not it should be just rematch the ports and that should be about it
4 Inch lift
Dana 80
ASA pipe BHAF 19037
A A nv4500
roxxx
Postby KTA » Fri Oct 16, 2009 12:51 pm
24V uses D ports. 12V uses rectangle ports. The manifold retains its rectangular cross section throughout. I think it would be an advantage to do that as well with a new one so it starts as a rectangle at the ports stays a rectangle in the tube and exits as a rectangle into the turbo so you could actually retain the same crossection throughout to minimize turbulence and maximize flow.
Postby roxxx » Fri Oct 16, 2009 6:20 pm
KTA wrote:24V uses D ports. 12V uses rectangle ports. The manifold retains its rectangular cross section throughout. I think it would be an advantage to do that as well with a new one so it starts as a rectangle at the ports stays a rectangle in the tube and exits as a rectangle into the turbo so you could actually retain the same crossection throughout to minimize turbulence and maximize flow.
Yep you hit the nail on the head, he did that with the prototype just may have to fine tune it
I am kinda choked I cant go to the GTG wifey is takin her truck and the snow is melted so i have to work in my old truck and get my axle problem figured out :mad:
4 Inch lift
Dana 80
ASA pipe BHAF 19037
A A nv4500
roxxx
Postby RSWORDS » Fri Oct 16, 2009 7:25 pm
I have a stock manifold around here if you need one.
RSWORDS
Postby KTA » Fri Oct 16, 2009 7:35 pm
Just use the same cross section as a stock gasket to maximize flow for a modded vehicle. Then it is already port matched. :lol:
Postby ahale2772 » Mon Oct 19, 2009 8:17 am
might be cool to make these manifold with different options say if someone was going to run a turbo with a t3 flange on a 12 valve truck
Postby cumminsduallyguy04 » Sun Dec 27, 2009 10:34 am
any finished pics? also any pics of it on the truck? i want one from the looks of the pic above
1991 dodge cummins getrag 2wd srw
04.5 dodge cummins 48re 4wd srw
04.5 dodge cummins g56 4wd drw
cumminsduallyguy04
Postby eyoung429 » Sun Dec 27, 2009 11:02 am
$700!! was considering on getting one but for that price, I would be buying tires for my rig first!!
guess I will be going back to a stock one if I can find one...the 2 I looked at have the ears missing in a couple of places.
<sigh>
1991 IC D350 2wd Dually,st cab, full 4in Magnaflow exhaust, 3.73 gears, auto 518,HX35....goin' to twins!!!
member of the cable pull club
eyoung429
