stock 1991 d350
stock 1991 d350
Postby stock91w350 » Sun Nov 01, 2009 2:05 pm
Just got a 91 d350, 4x4, duelwheel ,5spd and other than a big exhaust stack i think it is stock, what should be the first ten or so steps i shoud do to build power? how can i tell if my pump is turned up or if someone has turned the star wheel under the cap with the fuel pin? I did notice that the smoke screw now is a bolt and is turned all the way in but doesent seem to smoke to much and the smoke isent real dark. thank you
stock91w350
Postby 90FIRSTGEN CUMMINS » Sun Nov 01, 2009 5:44 pm
I would buy a gov spring right off the bat.
1990 W250 Non I/C, Mostly stock,4 inch Ex,Fuel Screw Turned Up a Little, 727TF, 366 spring, BHAF, Borgeson Steering Shaft, Under-bed B & M transmission cooler, head lights now on relays(just added)
90FIRSTGEN CUMMINS
Postby RumbleFish » Sun Nov 01, 2009 7:01 pm
gauges, asap. boost, pyro, and tach if you are putting a 3200 gov spring in it.
Re: stock 1991 d350
Postby Richie O » Sun Nov 01, 2009 7:13 pm
stock91d350 wrote:Just got a 91 d350, 4x4, duelwheel ,5spd and other than a big exhaust stack i think it is stock, what should be the first ten or so steps i shoud do to build power? how can i tell if my pump is turned up or if someone has turned the star wheel under the cap with the fuel pin? I did notice that the smoke screw now is a bolt and is turned all the way in but doesent seem to smoke to much and the smoke isent real dark. thank you
I am pretty sure the old owner had turned up the fuel some. He may have turned it back down. Did you get the miss out of that thing. I should have bought that truck. Seems Im running into you everywhere. :D You just suscribed to my youtube account. 8)
Postby Richie O » Sun Nov 01, 2009 7:16 pm
O and also its a W350. D means 2 wheel peel.
Re: stock 1991 d350
Postby stock91w350 » Sun Nov 01, 2009 8:00 pm
ha yea thats funny, are u in maine? what do u mean "did i get the miss out of it"?
stock91w350
Postby Richie O » Sun Nov 01, 2009 8:23 pm
It was skipping some at the drags this summer.
Users browsing this forum: No registered users and 62 guests
