dual piston brakes
dual piston brakes
Postby ahale2772 » Mon Nov 09, 2009 8:15 am
so this weekend I ripped apart my front end I need to do calipers u joints and wheel seals/axle seals, both of my front calipers are shot they barely move I expect the bores are rusty/ seals are gone because of the rust, I was wondering if anyone knew if a set of dual piston caliper will work I have a set from a bus sitting in my kitchen and they have all the same mounting dimentions but the spot for the brake line in is different it dosnet have the same banjo fitting, also I dont know if the master cylinder will be up to the task to feed 4 pistons in the front instead of 2, any input?
also what rear end/ brake set up uses a 13 inch drum with 2.5 inch wide pads? I have a rear end sitting around with new brakes and I am too lazy to pull off my rears on my truck to see if its all the same stuff will it work on my truck?
thanks in advance
Postby dpuckett » Mon Nov 09, 2009 9:34 pm
13x2.5 may be a SRW Dana80. The DRW Dana80 that went into Rumblefish's truck had 13x3.5s.
DP
Postby ahale2772 » Tue Nov 10, 2009 8:03 am
any clue how to tell what it is? im sure the numbers are rusted off
Postby Raymo » Tue Nov 10, 2009 8:54 am
If you're wondering how to tell if its an 80, look in my conversion thread and see how really tall, but narrow the diff cover is. But it does take a lot of rust to make the cast in "80" illegible
'94 Chevy 3500-HD cab and chassis- IC Cummins, Getrag, NP205. 60 front, 80 rear- 4.10's.
Raymo
Postby ahale2772 » Tue Nov 10, 2009 2:20 pm
yeah ive noticed that before i dont think its an 80 becase of the dif cover...I live in New england neer the water when it comes to rust anything is possible ive heard that a 70hd has no taper when the axle tube goes into the backing plate can anyone confirm that?
