Rockentech not so rocking?
Postby dragrdan » Tue Nov 10, 2009 9:21 pm
Well so far this thread has 350 views, and its all their customer base, so I figure I am bothering them enough, as well as informing potential customers of possible problems with their product, and definate problems in their customer service.
93 W250 5spd, Comp 275, HE351CW, 5X18, IP turned up, 3200 spring, BHAF.
dragrdan
Postby Richie O » Tue Nov 10, 2009 9:32 pm
I would have called the better buisness bureau. If in fact it was frigged up from the get go they should have replaced it of refunded it period. I would not be able to swallow that one.
Postby dragrdan » Thu Nov 12, 2009 5:39 pm
The BBB is a voluntary organization that they have to volunteer(pay) to join. There is really nothing they can do. Even if they go through arbitration with the BBB, they really don't have to follow or agree with the BBB's decision.
I agree that they should have offered an exchange or refund. If I were selling these, and got a report of a bad one, I would want it back. I would want to check it against the blueprint and see if it were made correctly. I would want to know if it were a problem in the design, or if it were just not made to print.
dragrdan
Postby burnt_servo » Thu Nov 12, 2009 5:40 pm
did you pay with a credit card ?
'93 w250 .... stock ...
burnt_servo
Postby dragrdan » Thu Nov 12, 2009 9:05 pm
wish I had :roll:
dragrdan
Postby burnt_servo » Fri Nov 13, 2009 5:57 am
they outright refused to take back their product ?
burnt_servo
Postby dragrdan » Fri Nov 13, 2009 7:50 am
When I first contacted them about the problem, I asked for an exchange. They wanted pictures, so I sent them the ones earlier in the post. They called me back and told me to grind it. I asked again for an exchange, they said if the fit bothers me to take a small hand grinder and grind it.
dragrdan
Postby dragrdan » Fri Nov 13, 2009 7:53 am
@ anyone else who has bought one of these: Is your still running ok without problems? I have been hearing about failures?
dragrdan
Postby ford69557ci » Fri Nov 13, 2009 9:51 pm
I ran one in my test pump with no probs besides the defueling issue.
ford69557ci
Postby fergavs » Sun Nov 15, 2009 1:06 am
I had one in my 14mm/4mm combo pump. It seemed to be fine before it tore the ears off. I think that was from too small a test injector backing up the fuel in the pump which caused it to load up to much. Something just had to break. As far as clearence and such that wass all fine but it took a lot of set up to get everything within Bosch spec.
fergavs
Postby cummins king » Sun Nov 15, 2009 1:52 pm
ive torn the ears off mine to.
93 4X4 auto
cummins king
Postby dragrdan » Mon Nov 16, 2009 7:19 am
Was wondering about it. As I said the Bosch factory piece looks like its machined from a forging, and I couldn't tell about the Rockentech piece.
dragrdan
Postby dragrdan » Sat Nov 21, 2009 10:34 am
Well just got the bill on the machinework, $220. For Chamfering the ID of the roller ring, the OD of the governor housing(yup needed clearance there too.) and milling the "cross"(didn't want to weaken the camplate by taking anything off it).
dragrdan
Postby burnt_servo » Sat Nov 21, 2009 12:45 pm
dragrdan wrote:Well just got the bill on the machinework, $220. For Chamfering the ID of the roller ring, the OD of the governor housing(yup needed clearance there too.) and milling the "cross"(didn't want to weaken the camplate by taking anything off it).
mail them the bill :D ......
is small claims court there an option ?
burnt_servo
Postby dragrdan » Sat Nov 21, 2009 9:28 pm
I'll just take it as lesson learned, and spread the knowledge.
What other sources are there for VE custom parts?
dragrdan
