Leaky Injector
Leaky Injector
Postby Jfriedlin » Mon Nov 16, 2009 2:27 pm
Finally got my truck goin again but my #1 injector line is leaking like a sift. Is there an o-ring that may be in bad shape on top of the injector or did I crack the flared end on the metal line? If thats the case does ayone know a good place to get replacements?
BTW its a 1989 Cummins
Jfriedlin
Postby PToombs » Mon Nov 16, 2009 6:35 pm
No o-ring in the top, it's metal to metal. Just loosen it a little and try to tighten it again. They don't need to be super tight, just snug. If it keeps leaking, pull it and have a look. If it's rusty looking in the top of the injector, it can be cleaned carefully with some emery and a blast of brake clean to blow it out. Same with the line. If the line looks cracked or deformed, time for a new one.
You can get a line at the case/ih dealer if that's closer than a cummins dealer. Say it's for a 621 loader, it's the same thing.
Postby Richie O » Mon Nov 16, 2009 6:37 pm
Pete, Do the case rigs with the B's have VE's ?
Postby PToombs » Mon Nov 16, 2009 6:44 pm
Most of them. Some of the 4b's had the Lucas CAV, some of the farm tractor 6b's too.
Postby Jfriedlin » Mon Nov 16, 2009 9:36 pm
Thanks, ill have to check into that tomorrow.
Jfriedlin
Postby Jfriedlin » Thu Nov 19, 2009 12:33 pm
Got my new injector line and put it on today. Seemed to fix the problem and I've got a lil smoother idle now
Jfriedlin
Postby PToombs » Thu Nov 19, 2009 6:14 pm
Glad to hear it! 8)
