whats the best turbo to go with
Postby adam greene » Sat Nov 21, 2009 7:29 pm
i have a 93 d-350 i want a little more power out of it whats the best turbo to go with.
adam greene
Postby skilletky » Sun Nov 22, 2009 8:09 am
what all is done to the truck and what are your plans for it?
skilletky
Postby adam greene » Sun Nov 22, 2009 4:08 pm
just a few pump mods nothing major i just want a little more power
adam greene
Postby skilletky » Sun Nov 22, 2009 4:37 pm
put ya a smaller exhaust housing on it and maybe a crompressor wheel upgrade.
skilletky
Postby Swaggs » Sun Nov 22, 2009 8:03 pm
would a 60 mm compressor wheel be an upgrade on a 93?
92 W250 CTD, Getrag, hx35, DiamondEye, Mostly Stock
89 Ramcharger 360/727
'92 W250 CTD, Lifted Sold
'96 2500 CTD Sold
Swaggs
Postby stoneagemaxx » Mon Nov 23, 2009 7:00 am
yes it is an upgrade over stock i've run one for a couple years you will deffinently need a bigger turbo or twins using the 60mm upgrade if your looking for big HP, since i just woke up i'm not exactly sure what HP its good too but i belive it would get you into almost 400's with adequte fuelling mods 8)
91 d250. 2wd std cab i/c convert 3.07 rears autometer guages htt stage 3 turbo 47rh convert 2 manualy controled od an lockup turns on fuel screw .5 on smoke screw and fuel pin rotated 3800gsk timing jumped 1 tooth retarded on pump settings for now resealed ip to come in spring he351ve and full 4 in ex hopefully injectors coolertubz for the other rig thanks Tim
stoneagemaxx
Postby peobryant » Mon Nov 23, 2009 2:02 pm
Swaggs wrote:would a 60 mm compressor wheel be an upgrade on a 93?
If you are staying stock, or very close to stock, then you'd be okay with one. If you plan on bigger injectors, stay away from it, in my opinion. Most people who have spent the money on the 60mm comp wheel, have said they wish they would've saved for a better turbo.
The next turbo I'm getting will be a 60/68/14 S300. It is supposed t spool quick, and support more than enough horsepower for me. (I plan on being around 400rwhp.) My brother should be getting one for his new '97 soon, so I'll know more information then. :D
Postby Swaggs » Mon Nov 23, 2009 4:59 pm
gotcha, the reason I asked was because I saw a chart that stated the stock sizes of turbos, and I thought it said 91.5+ had 60 mm compressors already.
'96 2500 CTD Sold
Swaggs
Postby PToombs » Mon Nov 23, 2009 6:24 pm
91.5 to 93 have 56mm compressor wheels.
Postby 92 D/UNIT » Mon Nov 23, 2009 6:54 pm
Like peobryant said. if you are planning on keeping it mild, its a great upgrade, but if you are like many of us and dont know where to stop, save your money for a S300 variation. I have nothing but great things to say about my 62mm HTB2. I wouldnt pay what high tech asks for them though.
388/886
92 D/UNIT
Postby burnt_servo » Tue Nov 24, 2009 2:25 am
92 D/UNIT wrote:Like peobryant said. if you are planning on keeping it mild, its a great upgrade, but if you are like many of us and dont know where to stop, save your money for a S300 variation. I have nothing but great things to say about my 62mm HTB2. I wouldnt pay what high tech asks for them though.
+1 on this
once the power bug gets you , you will be looking at the very least a hx40 or s300 .
there is no real sense in getting anything smaller , unless it's free , or the next thing to it .
unless you feel like a lot of playing and fiddling , then there are the HUGE vnt style turbos off of the new 6.7 cummins that can be had off of ebay for around 100.00 .
but expect to put a lot of time and effort into making it work reliably .
'93 w250 .... stock ...
burnt_servo
