Ace wrote:Too bad you didn't start using the WMO a long time ago before the ULSD took it's toll. If it's not bad injectors, then the VE's worn. Maybe both.
Mine doesn't seem to like synthetic WMO.. Doesn't show up right away, but usually about 2 tanks later, then takes forever to go through the system .chico_mustangs wrote:Well it turned out that the diesel and WMO I had in the tank either didn't mix or I had a LOT more oil in the tank then diesel. 3 tanks ago I drove it around to the point where I had 1/2 gallon or less of fuel in it, filled up an no more smoke thank god! So I have since started putting about 1-2 gallons on motor oil when I fill up and no smoke issues. Thanks for all of the help guys!!!
MMeier wrote:Mine doesn't seem to like synthetic WMO.. Doesn't show up right away, but usually about 2 tanks later, then takes forever to go through the system .chico_mustangs wrote:Well it turned out that the diesel and WMO I had in the tank either didn't mix or I had a LOT more oil in the tank then diesel. 3 tanks ago I drove it around to the point where I had 1/2 gallon or less of fuel in it, filled up an no more smoke thank god! So I have since started putting about 1-2 gallons on motor oil when I fill up and no smoke issues. Thanks for all of the help guys!!!
921stgen wrote:I ran at least 10 gals every tank for 3 years until my trans when out 2 months ago. In winter and summer.
