james-93-12valve wrote:Ace i ment like half and half sorry wats #2 diesel is it just ulsd
burnt_servo wrote:fill a pop tester with the fuel you are going to be using , and " pop test " one of your injectors with it .
if you don't get a fine mist out of it , DON"T USE IT .
i've found with vw injectors that anything over 30% veg oil / 70% diesel , and you get a stream of liquid , not a spray...
