stock head gasket
stock head gasket
Postby jwatso8 » Sat Dec 12, 2009 3:27 am
what boost pressure does the stock head gasket and bolts let go?
SOLD 92 D250 intake,S300,coolertubz,i/p MAXED,366 spring,Dennyt fuel pin,DDP 4,airdog 100,gauges, 4" d/p w/5" stacks
TRADED IN07 2500 6speed,intake,CFM+,Edge EZ chip,MBRP exhaust,B&W hitch
NEW 2010 3500 6.7L DRW 4x4 CrewCab 4.10 grears
jwatso8
Postby peobryant » Sat Dec 12, 2009 4:18 am
Some go at 35psi, others go at 60psi. You can retorque the stock bolts to hold more boost, but not everyone has good luck with that.
Postby KTA » Sat Dec 12, 2009 8:06 am
When head gaskets blow also has a LOT to do with timing and exhaust back pressure. IE smaller turbines and housings blow at less boost pressure than big ones. Most will hold 30-35psi regardless if things are right.
