new to this
Postby ahale2772 » Mon Dec 28, 2009 1:05 pm
no egts are the main reason the turbo would grenade in the first place, cummins makes a piston liftpump i believe the price on the recently went up, ur gona need one if u want more power the stock lp barely feeds an untouched pump,
Postby new dad » Tue Dec 29, 2009 7:04 am
ok thanks for the info. can you make a home made water injection system? ive heard some people say stuff about using the windshield washer fluid system? is there any truth to this?
98 3500, 5sp, dpp 90's, 10 plate, 4k springs, sb fe. totalled
90 d250 727, stock for now, coming soon: trans swap from a '95 2nd gen, 366 spring, m&h m5, custom crossover plumbed for a little w/m and n2o
new dad
Postby ahale2772 » Fri Jan 01, 2010 5:10 pm
i dont think the water would atomize correctly
Postby new dad » Fri Jan 01, 2010 9:31 pm
what is needed for proper atomization? high pressure pump?
new dad
Postby IowaCummins » Fri Jan 01, 2010 10:00 pm
most kits sell a 150 psi surflow pump but now there is a 200psi pump that they are selling.
IowaCummins
Postby lectro_static » Fri Jan 01, 2010 10:26 pm
I have been looking into water/meth also here is a link to a diy site with places to buy parts and part numbers etc
http://www.turbomirage.com/water.html
weeping head gasket
4" straight pipe
M&H M3 fuel pin
M&H Dynamic Timing Advance
366 spring
Auto Meter EGT and Boost
lectro_static
