power loss
power loss
Postby stock91w350 » Sun Jan 03, 2010 6:21 pm
I took my stock 1991 1ton truck and did a couple upgrades and when i was done i had less power and less smoke. i turned the fuel pin so the steeper side was fueling, i turned the star wheel 2 turns down, i watched a instructional video on how to do this while i did it. when i fel t less power and saw less smoke i put it back exactly the way it was and still less power and smoke. what could of happened? its like at half throttle i can floor it and nothing happens still seems like half throttle. ant ideas? thank you
stock91w350
Postby stock91w350 » Sun Jan 03, 2010 6:27 pm
also its a 5 spd manual and even if i downshift and hammer down up a hill it still bogs down and slows down, the truck starts idles perfect other than the lack of power, it pushes snow better than any truck ive seen tho, so it seems that pulling and pushing power is great but speed power bad
stock91w350
Postby Richie O » Sun Jan 03, 2010 6:42 pm
You sure the deepest side of the fuel cone is to the front?
Postby stock91w350 » Sun Jan 03, 2010 6:52 pm
yea i actually kept second guessing myself so tried it turned a bunch of ways some was worse than others,i have a bully dog pin and a 3200spring on the way, guess ill see what happens after i put them in. should i turn the starwheel down and how far if so? the truck only has a stack and the pump turned up some, the smoke screw is a bolt with no cap over it so someone messed with that also i guess
stock91w350
Postby PToombs » Mon Jan 04, 2010 7:01 pm
Are you sure you turned the starwheel the right way? Clockwise as you look down on it? The only other thing I can think of is maybe the fuel pin that rides the cone is stucking. Pull the cone, and give the truck full throttle while you watch in the hole. (not running) The pin should shoot right out. If not, maybe spray some lube on it, then try to move it again. You need to push it back with a screwdriver before you put the cone back in.
Postby burnt_servo » Mon Jan 04, 2010 7:51 pm
is the pressure line from the turbo / manifold hooked up , and in good shape ?
'93 w250 .... stock ...
burnt_servo
Postby stock91w350 » Mon Jan 04, 2010 7:54 pm
burnt_servo wrote:is the pressure line from the turbo / manifold hooked up , and in good shape ?
not sure what that is? wher is it located? is it a metal or rubber line? thank you
stock91w350
Postby oldestof11 » Mon Jan 04, 2010 8:28 pm
Metal. Goes from the head to the top of the pump where you went into to make the changes. This is the line that you need to disconnect before taking the 4 screws out of the top to access the fuel pin.
Postby stock91w350 » Mon Jan 04, 2010 8:30 pm
oldestof11 wrote:Metal. Goes from the head to the top of the pump where you went into to make the changes. This is the line that you need to disconnect before taking the 4 screws out of the top to access the fuel pin.
ok yes it seemed to be in real good shape with no crimps
stock91w350
