not sure what that is? wher is it located? is it a metal or rubber line? thank youburnt_servo wrote:is the pressure line from the turbo / manifold hooked up , and in good shape ?
ok yes it seemed to be in real good shape with no crimpsoldestof11 wrote:Metal. Goes from the head to the top of the pump where you went into to make the changes. This is the line that you need to disconnect before taking the 4 screws out of the top to access the fuel pin.
